MTX 5
Old 10-24-2011 | 10:33 PM
  #1291
chippy's Avatar
Why would you do that the clutch in the 5 is awesome...
chippy is offline
Old 10-25-2011 | 02:23 AM
  #1292
Originally Posted by bigbank66
Have anyone put a capricorn clutch in there 5 yet??? an if so which one?? I hate to say it since im a mugen man....but the cap clutch is the best on the market!!
no real need bro. Just shim the bell untill it's free from contact on the shoe, then give it a gap of .4mm to .45mm and .05 to .1mm end play. tighten the spring flush with the pilot shaft nut when the spring is new then wind it in a little once the spring is worn in.
too easy.
i could only imagine how incredibly punchy the clutch would be with a red shoe and an alluminium clutch bell!
TomB is offline
Old 10-25-2011 | 05:27 AM
  #1293
FF25510's Avatar
Originally Posted by Ghett0
can you still lean your motor out? how about the pipe/header you select? by the way. nice mercedes-benz
i found out the reason today, a bad front bearing. i replace it to a MAX WC and this time ... one more thing, i strip 1 1st and 3 2nd gear yesterday and i finally found out cause by the too sharp pinion gear problem gone after replace all spur/pinion gear. love to drive this car sorry, it's not a Benz, it's a TOYOTA CROWN from Japan.
FF25510 is offline
Old 10-25-2011 | 12:05 PM
  #1294
Francis M.'s Avatar
Glad you found the problem with your engine...
Francis M. is online now
Old 10-25-2011 | 07:36 PM
  #1295
bigbank66's Avatar
Thanks TomB....i was on a well prep track....it was crazy how the cap were able to come out the corners...i love what i have seen out of my mugen so far...Chippy its just a question an if u r a true racer you must know the caps clutch is a wanted part...
bigbank66 is offline
Old 10-26-2011 | 01:44 AM
  #1296
Robert Pietsch is a true racer and he won the european championship with the MTX5 original clutch!
I will never use the Capricorn clutch on this car. Not saying that it´s not good. Just that there is no need.
Best regards
Luís Cortez is offline
Old 10-26-2011 | 03:15 AM
  #1297
Mazda614's Avatar
Default MTX 5 Diff Gears
Has anyone worked out if NT1 or other manufacturers diff gears fit the MTX 5. I am looking for steel or alloy diff gears to fit the MTX5.
Mazda614 is offline
Old 10-26-2011 | 04:53 AM
  #1298
chookgb's Avatar
the xray gears will fit in, although they are thinner then the mugen gears so they need shimming to achieve the correct mesh. I am still working on the exact shim sizes to achieve the best result, i will let you know when and if i get it right
chookgb is offline
Old 10-26-2011 | 05:20 AM
  #1299
Thunderbunny's Avatar
I tried the NT1 gears. I stripped a set due to incorrect spacing. I now have a set of Shepherd gears that I have yet to install. I'll post my findings.
Thunderbunny is offline
Old 10-26-2011 | 05:38 AM
  #1300
very good , ive only ran nova's and RB's and to b honest both engine's are very strong and hold tunes well, good you worked out your bearing issue ... keep me posted if you keep stripping gears, 4 in 1 day is alot . btw your toyota looks like a benz 550, very nice toyota crown ....
Ghett0 is offline
Old 10-26-2011 | 05:54 AM
  #1301
DS Motorsport's Avatar
It's not just the Capricorn clutch which makes for the tremendous acceleration but it's the entire car.
The clutch has a big part in the massive acceleration though, but the driveline weight and efficiency also plays it's part.
At this moment Capricorn doesn't have a clutch which will fit the MTX-5.
DS Motorsport is offline
Old 10-26-2011 | 06:29 AM
  #1302
FF25510's Avatar
Max as well, i will attend the biggest event of the year here in HK on Nov 5/6 an i will race with my MRX/MTX 5, hope to have something to post back here
FF25510 is offline
Old 10-26-2011 | 08:11 AM
  #1303
wingohung's Avatar
ofcourse you will
wingohung is offline
Old 10-26-2011 | 08:59 AM
  #1304
what body you running for 1\10th; and are you using nova motor?
Ghett0 is offline
Old 10-26-2011 | 05:26 PM
  #1305
FF25510's Avatar
Originally Posted by wingohung
ofcourse you will
haha, who knows, let us try our best
FF25510 is offline
