Like Tree5Likes
SC10 4x4 Thread
Old 10-14-2011 | 11:14 AM
  #8656
BlueGlowBoy's Avatar
Originally Posted by Krio
Yes, the taller wall holds the pads static, but you throw an extra slipper plate between them like the MTK clutch basket. In essence a built in clutch basket on both sides of the spur that you can add as many or few slipper pads/plates to as you want.
You can put as many pads and plates as you want together, but if the only slipping is happening between 1 pad and the plate, you aren't doing anything other than adding more weight....
BlueGlowBoy is offline
Old 10-14-2011 | 11:15 AM
  #8657
symmetricon's Avatar
Thought a 3rd diff was not allowed, so is'nt the Duragoes middle diff all locked up ?
The rango has a slipper on the centerdiff, and it can be locked or used as a typical diff.
symmetricon is offline
Old 10-14-2011 | 11:18 AM
  #8658
Wild Cherry's Avatar
r there are gears in its middle diff ?
cus a slipper is not anything like a diff....
Wild Cherry is offline
  #8659
The plates between each pad are keyed to the slipper shaft. Have you seen the MTK clutch basket as a reference?
Krio is offline
Old 10-14-2011 | 11:41 AM
  #8660
CraigMBA's Avatar
I can answer that - no, because if he had, he wouldn't of posted what he posted.
CraigMBA is offline
Old 10-14-2011 | 12:37 PM
  #8661
Artikbot's Avatar
EPIC QFT
Artikbot is offline
Old 10-14-2011 | 12:48 PM
  #8662
It is a gear diff. When you buy the truck, it doesnt come with gears in the diff, it is locked, so you have to buy the internals. But with that said, there is a slipper built into the outside of the diff.
Old 10-14-2011 | 01:28 PM
  #8663
100% true. In all the pictures I have seen of the clutch basket, I could not see/did not notice that the plate that goes between is keyed. now that I see that, I also realize that the clutch basket is actually tripling the surface area. That makes a lot more sense now.
Thank you.
(BTW, I'm not stupid, I'm ignorant.)
Old 10-14-2011 | 01:46 PM
  #8664
Artikbot's Avatar
Thank you.
If you look at the SS disc, it's got the same shape the slipper discs do. That's what locks down to the shaft.
Artikbot is offline
Old 10-14-2011 | 03:02 PM
  #8665
1Fastpede's Avatar
Any ideas on why the shim inside the diff bends? my diffs have a ton of drag because of this and I'm not buying a whole diff rebuild kit for some shims. mcmaster here i come.
1Fastpede is offline
Old 10-14-2011 | 03:10 PM
  #8666
I would be willing to bet that the inside washer gets like that due to the play in between the diff cup and the outdrives. Mine got real bad. I noticed that the brass insert had worn so badly that when you would bobble the outdrive, it would place alot of pressure the sungear pin, which would press into the washer you are talking about.
I would sure love to have steal instead of brass in a high wear area like that. wink wink someone
Old 10-14-2011 | 03:21 PM
  #8667
1Fastpede's Avatar
i just refuse to buy a full diff kit for 2 washers
Old 10-14-2011 | 03:31 PM
  #8668
Not allowed to use the gears with the slipper , somebody correct me if I'm wrong ...
Old 10-14-2011 | 03:39 PM
  #8669
the slipper assembly doesnt change when going froma a locked diff to a gear diff. Tightening or loosening the slipper is a matter of personal preference.
Old 10-14-2011 | 05:43 PM
  #8670
Divey's Avatar
Does anyone know how to get a hold of Trakstar. I have called and emailed and get no replies back. It's been 2 days short of a month since my order. This is starting to get ridiculous now. Anyone?
Divey is offline
