MTX 5
Old 09-29-2011 | 04:12 AM
  #1021
Pattojnr's Avatar
Originally Posted by bertrandsv87
Dls is a whole lot of fluffy weight added on to the car for show ! It has not made a difference in the serpent 733 , except making people leave for xray....lol... A huge waist...Leave the Mtx5 free of crappy serpent parts ok !!!!!!!
the DLS has its place. i agree is a bit of extra weight, but you are silly to say it makes no difference. i can say with times and results to back it up, it is faster on a low to mid traction track. how much faster ? for me 0.4 faster avge.
Pattojnr is offline
Old 09-29-2011 | 04:29 AM
  #1022
Bishop's Avatar
Pulling out one engine and fitting another tonight, found the source of a slight weirdness setting my clutch, the little end insert on mine is drilled off center, you can see it from the end, and when you rotate it in something smooth it's certainly off center.
I'm not sure it effects the clutch in action, though it likely is not great for the trueness of how everything rotates around it, or maybe how it buts against the end of the engine shaft perhaps, not sure how I missed it during the build, weird quality control issue from Mugen.
Bishop is offline
Old 09-29-2011 | 04:42 AM
  #1023
Chickentrader's Avatar
You should be able to use an end shaft of any make of clutch; as long as it's not shorter that the original, if you are short of a replacement. You can shim the end play if the shaft is a little longer. Jeff would have one for sure.
Kindest regards,
Lars.
Chickentrader is offline
Old 09-29-2011 | 05:00 AM
  #1024
I had the same on one of my clutches, the other where drilled perefctly..
Clutch did not work good and was very unstable in operation
chovden is offline
Old 09-29-2011 | 05:42 AM
  #1025
Bishop's Avatar
Kindest regards,
Lars.
The clutch on the new Mugen is quite unique, the bell and gears are very long, meaning that end shaft insert is also possibly twice the length of anything else out there.
I'll run it as is right now, though will order a new bit asap, not sure what it was effecting, maybe nothing, maybe making it stick at some point in it's action.
Bishop is offline
Old 09-29-2011 | 07:20 AM
  #1026
JRGTR's Avatar
Originally Posted by Seisick
i have the mugen pinionremover but unfortunately does not work with the new pinions!
i also have the plastic ones from serpent and the 20 teeth pinion barely grabs it, so what are you guys using????? maybe the rrr works as it has 15 and 20 teeth pinions????
I use Km pinion tool!!!, the only thing or small detail is that you need to dremmel a little the same adaptor use for mugen clutch bell to fit and is done!!!
JRGTR is offline
Old 09-29-2011 | 07:50 AM
  #1027
Seisick's Avatar
Originally Posted by Ghett0
this is the 733 dls arm, thats all, it acts as a brace.... it is an option and will be released from mugen
mugen pinion tool
for now i guess i will have to do that, ihave broken and bent allen L wrench since
on very tight pinions but til then ill guess ill have to stick to mine!
Seisick is offline
Old 09-29-2011 | 11:17 AM
  #1028
rave1010hk's Avatar
We have occurred in the Diff gear problem?
rave1010hk is offline
Old 09-29-2011 | 11:11 PM
  #1029
Default PROBLEMS WITH BRAKE
This brake system is install it like the manual says.. the car is ready to run. With the radio I apply the brake, (even with the hand) and donīt feel it so well, with dificulty continues rolling, i meant, the car donīt stop. I am checking again and again the manual and the system is build like the manual. somebody can give me a sugestion? The trims and substrims are ok. Thanks.
yshmana is offline
Old 09-30-2011 | 01:34 AM
  #1030
On mine I had the same, I sanded the pads a little as they where far from flat and after some driving to breake them in they are now good, they just take some time to breake inn so al of the pad presses against the disk
chovden is offline
Old 09-30-2011 | 05:55 AM
  #1031
MugenDrew's Avatar
Just like on a real car the brake pads must be bedded in. If you do choose to sand them I would use 400 grit or finer paper. Do spray out the pads with brake cleaner to make sure there is NO oil, grease, finger prints etc. I would not sand them...
MugenDrew is offline
Old 09-30-2011 | 12:04 PM
  #1032
Bishop's Avatar
Yep, the brakes don't grip until bedded in, and they like a moderate amount of that, mine are good now, but they need an effort to start working well, and yes wipe off the brake hardware with meths, it's got oil on the rotor etc, and that is not great for a real style of brake compound.
I had my Mugen at the track last night, not racing it just running some track tests to see if what I did helped my issues, can't remember if I said but I drilled my front shock pistons with a second hole, and pushed in the top shock mounts.
Good news is it steers now, and has front end traction into and mid corner, so all good, working on larger setup but it's generally balanced now.
Bishop is offline
Old 09-30-2011 | 12:28 PM
  #1033
Thats good to know Bishop,I just dont understand what you did by pushing in the top shock mounts,you meant shock position or really pushing the top mount into the shock body?For the record I haven't received my car yet.
30Tooth is offline
Old 09-30-2011 | 02:53 PM
  #1034
afm's Avatar
afm
Que pasa pepe, hay que asentar los frenos pues...estan nuevos
Slds
Papo
afm is offline
Old 09-30-2011 | 04:36 PM
  #1035
I think you should check how you put together the brake assembly. The collars that center the pads can lock down one pad when they are tightened. They stop the brakes from working and the car will not stop.
Page 11
Part T2309A centers the pads and springs that keep the pads apart. Before you tighten this part make sure the pads move freely than tighten them down..
rangulo is offline
