Like Tree5Likes
SC10 4x4 Thread
Old 09-02-2011 | 08:20 AM
  #7111
Yeti AS3's Avatar
Originally Posted by Vegatron75
I've got the stock springs and the stock shock bodies.
What did you dremel? The flat at the bottom of the shock body?
Here ya go. The flats are smaller now.
Yeti AS3 is offline
Old 09-02-2011 | 08:30 AM
  #7112
1Fastpede's Avatar
Originally Posted by kevink123
put a tekin 4.5 sc4x in yesturday and run on a indoor clay track and think i'm actually slower then when I had a lrp 6.5 540 in it lol. The 4.5 is to torquey all the throttle is right in the beginning where as the 6.5 is way smoother and the power is more on the top so you can work the throttle better no so on/off. I think i'm gonna switch it back before the race tomorrow.
yea the attitude of the truck changes from 540 to 550. i feel the truck prefers the 540. however I'm running a boosted 8.5 at 15/93. its faster than my tekin sc4x 4.5 curious how a 6.5 would run but something tells me not much faster than my boosted 8.5
1Fastpede is offline
Old 09-02-2011 | 08:31 AM
  #7113
1Fastpede's Avatar
Old 09-02-2011 | 09:11 AM
  #7114
AccessRacer's Avatar
I agree, this truck is AWESOME, but mine was built the "Wright" way by Jimmy Wright aka Racecrafter. Proline Trenchers are awesome too.
AccessRacer is offline
Old 09-02-2011 | 10:01 AM
  #7115
Artikbot's Avatar
M2 compound is enough durable to race at least half a season with them? Will put around 4-5h weekly through them.
Artikbot is offline
Old 09-02-2011 | 11:02 AM
  #7116
BLbound's Avatar
I saw the pic of the new rpm arms...I hope they are made of a stiff plastic rather than the typical rpm flexy plastic
BLbound is offline
Old 09-02-2011 | 12:53 PM
  #7117
Vegatron75's Avatar
Originally Posted by 1Fastpede
Thanks guys. Using the tip from Pede, I was able to grind down the overlapping part of the spring enough for it to sit level and work as it should. Nice.
Someone should add "squaring off" the springs to the first page. 3 of my 4 rubbed.
Thanks again y'all...
Vegatron75 is offline
Old 09-02-2011 | 02:10 PM
  #7118
BLbound's Avatar
Going racing tomorrow at west coast. Last time I was there I needed just a little more steering. So I went to 27.5 from 25 in the rear & went to yellow springs instead of blue in the rear. I was thinking of going to 20k in the front diff from 30k but I wasn't motivated enough to take out the front diff . Hopefully my changes will be enough.
BLbound is offline
Old 09-02-2011 | 02:20 PM
  #7119
BlackLabelVinyl's Avatar
Could someone please share a high bite no sway bar set up? Thanks. I have all of the away bars and springs, truck is pretty loose in the rear.
BlackLabelVinyl is offline
Old 09-02-2011 | 03:01 PM
  #7120
Artikbot's Avatar
My shocks rub on the cartridges, and I don't care at all. I'd rather have them rubbing than dremeling out the cartridge.
OR even better, I'd rather buy aftermarket 1/8 springs of similar stiffness but made for 14mm or bigger bigbores and adapt them to the needed length.
@BLV: I don't have my setup sheet, but right now I'm rather happy with my setup.
Running with stockers, but with AKA Rebars/GridIrons side bit should increase a fair bit. The rear end is a bit loose under gentle throttle, but very controllable and predictable on the sliding. Will get Proline Calibers in short, will report with them.
Full stock setup, 4oz ballast in front of the ESC (right at the front of the middle chassis), rear body mounts one notch away from the maximum height, front body mounts at the very middle (increases downforce and helps with grip at high speeds/loose corners). 5000mAh 2S stick pack, 26mm high (it's one of the first hardcase high end LiPo packs made, IP 5000mAh 25C), rather heavy. Probably in the same weights as a current 5600mAh Reedy stick.
Screw it, I'm making the setup sheet.
There ya go:
Artikbot is offline
Old 09-02-2011 | 03:18 PM
  #7121
Mine rub the shock bodies quite a bit, more so on the rears.
Mine does also rub quite a lot but only the rear ones.
Originally Posted by Cameron Kellogg
They need a new spring maker. You can bend them some and move around the lower retainer and sometimes you can get them not to rub.
This may work but it's a very temporary fix. After a pack or two they start to rub again... at least for me.
macke is offline
Old 09-02-2011 | 03:35 PM
  #7122
Vegatron75's Avatar
I used a cut-off wheel and ground the ends of the spring wire itself down. It worked and I didnt' have to grind the shock bodies. Give it a try, much smoother action w/o the rub.
Old 09-02-2011 | 04:13 PM
  #7123
symmetricon's Avatar
hey guys, i have a newish(used once in the street, bought last week) clutch basket and 3 HT slipperpads I want to sell. 30 Shipped, PM me.
symmetricon is offline
Old 09-02-2011 | 06:45 PM
  #7124
Default Check it!
Ok, I tried something new today, a slipper pad made differently. It worked amazingly well. Check it out. If your interested , pm MantisWorx. I think these could be the future of slipper pads!
Old 09-02-2011 | 07:20 PM
  #7125
Botwoon's Avatar
What's different about them?
Botwoon is offline
