SC10 4x4 Thread
#5611
#5612
This seems to let you get the 3mm of rebound on RC set-up. With the screws in they will rebound about 50%. On my local track's it seems the less rebound the better.
#5613
I ran about 60 minutes (3 race days, 3 qualifiers, 1 main, all 5 minutes) on the stock setup, but without the bleeder screw, before rebuilding the shocks and the old oil coming out was every bit as clear as the new oil going in, except for 1 shock which had a slightly deformed bladder.... not only did that shock bleed a lot of oil all over the shock body, but the oil was pretty dirty too...
Just proves to me that, built correctly, the oil will stay clean for a LONG time...
#5616
Has anyone tried the new FT 13mm big bore shocks (on the 4x4) on the 2 wheel SC? I searched the the 2wheel threads with no luck.
http://www.amainhobbies.com/product_...Rear-Shock-Kit
#5617
#5618
I just got off the phone with my suspension guys. I asked them if they could DLC "Diamond like coating" my shock shafts and shock bodies. I have to send them my shocks to see if it can be done. Would anyone else be interested in this? DLC has less stinction then ti nitrade and wears a lot longer. On my Kawasaki KX 450F the front forks have DLC.
#5621
#5622
#5625
And they just look bad ass!
5Likes
