Team Associated TC6 Thread >
Like Tree20Likes
Old 09-01-2011 | 01:22 AM
  #3661
Originally Posted by Geberit
One question for Rick:
Why does AE still stick to the single steering bellcrank as all other brands go with dual steering bellcrank? Is there a special reason?
Maybe this was explained before but I didn't catch it.
If you look at the chassis, there isn't much space to fit a double steering post set up, this is something we are discussing on another thread at present (Reflex)
olly986 is offline
Old 09-01-2011 | 09:23 AM
  #3662
Rick Hohwart's Avatar
The single bell crank is what the TC6 engineer feels is best. I don't know if one works better than the other because I have never had a car that gives both options (for back to back testing) but the single system works pretty well on the TC6.
Rick Hohwart is offline
Old 09-01-2011 | 10:08 AM
  #3663
cwoods34's Avatar
I'll be testing dual-arm steering in 17.5 and possibly mod tomorrow........
cwoods34 is offline
Old 09-01-2011 | 12:51 PM
  #3664
Geberit's Avatar
This is just what I wanted to hear! I'm really satisfied with the car. I tried the front gear diff with putty like you suggested and boy I like it very much. If you tell me it works for you then it should work for me too.
Thanks for your respond!
G
Geberit is offline
Old 09-01-2011 | 10:56 PM
  #3665
Originally Posted by sandsurfer
Do you maybe have a tire rub, or maybe cva dogbone/axle binding when turned?
ther is no tire rub or cva axle rubing thanks for your help
bunny32 is offline
Old 09-01-2011 | 10:59 PM
  #3666
Originally Posted by Little John
I had the same problem open all of your shocks and check that the screw going through the piston into the shock shaft and make sure it didnt back out a little or completly and if it did throw a little blue locktight on it hope this helps.
hi little john i checked them all good mate but i did find the problem rear diff to tight
bunny32 is offline
Old 09-01-2011 | 11:06 PM
  #3667
Default hi
can someone help me does thetc5 springs fit tc6 shockers and what do u guys mean when they say 1-1.1.5 shock piston. and can u tell me what is the ballstud sliver and black whats the differences thanks guys
bunny32 is offline
Old 09-02-2011 | 02:16 AM
  #3668
Redwood's Avatar
The Tc5 Springs are the same as the Tc6 springs, which have actually been the same since the TC3 I think.
The pistons you mention have 2 1mm holes and a 1.5mm hole, they do not come with the kit but can be bought from Reflex Racing (http://www.reflexracing.net/proddetail.asp?prod=RSD006).
Black ballstuds have a short 'neck' whereas the silver ones have a slightly longer 'neck' under the ball, I think it is 0.75mm longer, which basically is like having a 0.75mm shim underneath a black ballstud.
Regards
Neal
Redwood is offline
Old 09-02-2011 | 04:00 AM
  #3669
Default hi
thanks neal for the info mate to good but one thing where would i get the sliver ballstuds from thanks
bunny32 is offline
Old 09-02-2011 | 04:37 AM
  #3670
sandsurfer's Avatar
You can get the silver 'long" ballstuds from amain and probably others. I know amain has them listed under tc5's. I would recommend getting the 10mm thread length if you are planning on using them for the front outer ball. I had the 8mm loosen using a 2mm ballstud washer and then it would not tighten again because the few threads it was using became stripped.
sandsurfer is offline
Old 09-02-2011 | 10:02 AM
  #3671
Regards
Neal
AE sells blank shock pistons so that you can drill them to your specifications such as 1,1,1.5.
These are an AE part so any hobby shop that sells AE should have them or can get them/
Old 09-02-2011 | 11:29 AM
  #3672
Maybell's Avatar
AE Blank 1/10 Pistons, #6463. They are made from a material that is easy to drill.
AE Silver ballstuds,#31285 10mm length, #31293 10mm Ti Ni
Maybell is offline
Old 09-02-2011 | 05:09 PM
  #3673
Buckaroo's Avatar
What method is everyone using to build zero rebound shocks? Drilling the cap and leaving the foams out?
Buckaroo is offline
Old 09-02-2011 | 05:22 PM
  #3674
FastPete's Avatar
RSD bladders with a hole in the cap....I will have mine tomorrow
FastPete is offline
Old 09-03-2011 | 07:35 AM
  #3675
Default hi
thanks mate i will look into it thanks
bunny32 is offline
