RC10B4.1 FT/WC
#5492
IDK if anybody can help me out. I was running the FTB4 and loved it so i decided to upgrade to the B4.1. I put the Maifield setup on it and it pushes out the door. The B4 has way more steering. any help would be great.
#5493
b4.1 is pushing, I have tried everything, orange kyosho springs front, black kyosho rear, short front link no spacers, rear link 1 spacer, 1deg camber front, .5 back, 3 deg toe in center w/.5 hubs, 2deg anti squat, 32.5 w/#2pistions front, 30w #2p rear. upper shocks all the way to inside, lower front outside, rear inside. 3 internal shock limiters front , 2 rear, m4 scrubs aka foams(red) front JC rips 1/4 oz in front, 17G FT lipo block with 3/4 oz across the backside of the battery 1/4 oz on the rear triangles
track is indoor, wet clay/ dust, smooth/bumpy med traction
WHY IS MY CAR PUSHING, it will push high speed entering corners slow speed tight corners...
thanks!
thanks!
#5494
thanks!
thanks!
Reduce the limiting on the front. 3 limiters on the outside holes of the arm probably leave you little to no droop. (you can just unscrew your shock ends to play with that before taking the shock apart to change the limiting).
And change the front oil to match the rear at 30wt.
#5497
My current set-up, RH 24mm F/R, front~inside top outside arm shock position, brown spring with 27.5 oil, rear is inside top inside bottom, silver springs,25w oil, zero deg. FT hubs. everything else is out of the box FT .1 manual. Mine turns like an animal, with the right driving style.
#5498
Long story short I can see it happening, to not take away steering on the tight stuff I would adjust driving style and not the car if you find it to be the case. Simply try turn the wheel less with the same speed to see if it's an issue....imo
#5499
#5500
