Like Tree5Likes
SC10 4x4 Thread
Old 08-16-2011 | 09:20 AM
  #6346
lcc65's Avatar
we could always strap a brick to the truck, The Losi cant push us around after that
lcc65 is offline
Old 08-16-2011 | 09:32 AM
  #6347
CristianTabush's Avatar
Default Adding Weight
Last week I added weight to my SC10 4x4. I started with 90g (3.2oz) additional to see the results. Since I added weight, I also stiffened the suspension to make the truck handle a little flatter. My truck now has blue springs rear and yellow front. With a blue swaybar front and yellow rear (could use a stiffer rear bar- it keeps making the truck more stuck).
The truck got much easier to drive and got faster and more consistent lap time wise. So I kept adding weight until the lap times started going in the wrong direction. The number I arrived to was 4.2 total ounces.
With the extra weight the truck does not have to be "driven like a 2WD" anymore. It lands better after jumps, it rolls over obstacles better, it corners flatter. It was 1.5 seconds on average faster on a track that runs 36+ second laps.
I got really close to the track record on a night where the grip was causing everyone to go about 0.5-1 seconds slower per lap vs the last week's results. My truck was 1.5 seconds faster than the previous week. I ended up the Top Qualifier by about 35 seconds (almost a lap). I beat my best time on the track in EVERY RUN. I ran an extra lap in the 10 minute main (and these are 36+ second laps!).
While the truck is still not at Losi Weight, It comes in at 6lbs 5oz and the stability gained from the weight genuinely made my car easier to drive, much more consistent and fast. Lap in, lap out.
I know a lot of people on here think that lighter is better. That's fine. For those that are actually curious to find out what a heavier SC10 4x4 will accomplish, will actually be pleasantly surprised.
CristianTabush is offline
Old 08-16-2011 | 09:37 AM
  #6348
Cain's Avatar
what locations did you add weight?
Cain is offline
Old 08-16-2011 | 09:43 AM
  #6349
lodhammerdin's Avatar
Originally Posted by Artikbot
Y'know what to do right...?
I like the 'slightly braking' technique. When they are coming too close, just 'tap' the brakes so they go onto the other side of your truck, and you can use them as a lexan cushion to avoid bumping the pipe
@symmetricon: So am I!! I like driving my Ferrari so much I wouldn't change it for a Charger RT
Haha, I did this a few times last week and the losi dousch got mad at me for putting him it the pipe, I lol'd and shouted back at him, "you put yourself in the pipe, im not letting you use me as you breakes, learn how to drive."
He comes to my pit after the race telling me I cost him the win and blah blah blah so I showed him the scoring/ timing sheet, I was lapping him while he was in third place. I laughed and walked away. All the losi guys at my track are like that, its never there fault and they never touched you. I like racing but they make it hard to have fun.
lodhammerdin is offline
Old 08-16-2011 | 09:52 AM
  #6350
lcc65's Avatar
Has anybody used the lightweight topshafts in the tranny's? Any abnormal wear or failures??
lcc65 is offline
  #6351
I have center saddle packs so they are along the sides, towards the back. Most of it is between the speedo/battery box and the center of the chassis. If you are running stick packs, you can add a couple of oz in front of the speedo, some in the receiver box and some in front/behind the battery. Just make sure that you try to maintain a good balance, side to side.
Old 08-16-2011 | 09:53 AM
  #6352
I added them and did not notice a difference. They are only about 2g lighter/pc.
Old 08-16-2011 | 09:58 AM
  #6353
symmetricon's Avatar
Hey Cristian, what tires are youusing at Mikes? and coud you do setup sheet for everyone?
symmetricon is offline
Old 08-16-2011 | 10:03 AM
  #6354
Tires vary, but last time I used grid irons, soft all around.
I like rebars and suburbs ok as well, but the grid iron is better I think. The track has been very dusty lately.
I'll get a set-up for you up soon.
Old 08-16-2011 | 10:05 AM
  #6355
scottmen's Avatar
I have used them as well. Only have about 8-10 packs through them. Haven't failed and haven't noticed and unusual wear.
scottmen is offline
Old 08-16-2011 | 10:06 AM
  #6356
Thanks, i have been wanting to try the rebars in hope that they would last a bit longer than suburbs or grid irons.
Old 08-16-2011 | 04:21 PM
  #6357
I just got a 4x4 roller and a MMP w/ 4600. Can anyone using this combo help me with choosing the right gearing. I'm not sure where to start.
hotrodhomi is offline
Old 08-16-2011 | 04:54 PM
  #6358
1Fastpede's Avatar
Pics?
1Fastpede is offline
Old 08-16-2011 | 05:02 PM
  #6359
ITS ME DAVID's Avatar
Page 1
ITS ME DAVID is offline
Old 08-16-2011 | 05:06 PM
  #6360
T-BirdJunkie's Avatar
CM36 or 1406 motor?
If it's the CM36 it won't survive.
T-BirdJunkie is offline
