RC10B4.1 FT/WC
Old 08-09-2011 | 08:28 AM
  #4891
Robert Drew's Avatar
Originally Posted by Matt Trimmings
Front Dk Yellow: KYOW5181-60
Black: KYOW5183-03
Dark Yellow: KYOW5183-60
As for the blue's, there is the cobalt blue: KYOW5183-72
And the Dk Blue's as well: KYOW5183-68
Thanks for the help Matt.
Robert Drew is offline
Old 08-09-2011 | 10:10 AM
  #4892
I have a very basic question. When building a new truck or buggy, if you put shock limiters in the shocks, how do you determine the amount you screw the shock ends onto the shaft? I have heard people talk about unscrewing 2 turns or something like that. Is the basic setup the number of limiters in the manual and then the shock ends all the way tight?
gguertin145 is offline
Old 08-09-2011 | 10:17 AM
  #4893
Wild Cherry's Avatar
I always screw the eyelets even with the threads on the shock shaft .
When you hear some twist the eyelet out by two turns ?
They are most likely using the outside shock position on the ft arm with no internal limiters .....
1 turn on eyelet = .030 limiter
Wild Cherry is offline
Old 08-09-2011 | 10:22 AM
  #4894
nice.
So you dont go all the way tight just till you cant see threads right?
Old 08-09-2011 | 10:35 AM
  #4895
jph
Originally Posted by bds81175
Try limiters inside the shocks. They reduce the amount of weight transfer from front to rear and vice versa under accel/decel.
Originally Posted by tecniquin2001
Try the Maifield Reedy Race Set up.....
For On power steering:
Add shock limiters in front to reduce droop.
More aggressive front tire.
Add weights to the Front compartment next to the servo-1/4oz in each side.
To stop spinning out when braking hard:
Reduce your Brake EPA
Best way to test it, go down the straight and slam on the brakes, if it spins out, your EPA is set too high, reduce the % on your EPA till the car doesn't spin out while braking hard.
I'm sure there are other suggestions, those are some you can try out for starters....
Thanks guys,
I was using the wrong plastic washers as shock limiters, and adjusting the EPA helped also.
Much better now, thanks again for your help.
jph is offline
Old 08-09-2011 | 10:37 AM
  #4896
aeRayls's Avatar
nice.
Per the team: shock ends all the way tight
aeRayls is offline
Old 08-09-2011 | 10:39 AM
  #4897
I do as the team does, some also do as you said as well...
Old 08-09-2011 | 11:36 AM
  #4898
racer1812's Avatar
Super Moderator
nice.
wrong
right
racer1812 is offline
Old 08-09-2011 | 12:33 PM
  #4899
Thread the eyelets all the way & measure if you think I'm wrong ...
you can find as much as .030 difference between two shocks threaded all the way ....
Old 08-09-2011 | 12:51 PM
  #4900
So what would I measure? What is the setting they say to have it at?
Old 08-09-2011 | 12:59 PM
  #4901
No setting , just a matter of which method comes out more even or more equal when building two shocks ...
If your a perfectionist , you would measure with calibers after assembling and check to make sure the shocks are equal when fully extended out from the body.
Old 08-09-2011 | 01:00 PM
  #4902
brian cox's Avatar
measure from the bottom of the shock body to the top of the rod end-there is no magic number,just make sure the left and right are the same!
brian cox is offline
Old 08-09-2011 | 01:06 PM
  #4903
Ok so I was already making them the same with a caliper... I guess where I was going is if the shock is longer or shorter based on how far you thread the ends on wouldn't that affect handling?
Old 08-09-2011 | 01:18 PM
  #4904
More important to have both shock equal ,then knowing how far a team driver threads his shock eyelet on the shaft ....
Old 08-09-2011 | 01:22 PM
  #4905
Ok so I am just trying to learn so please forgive any ignorance.
Why does it matter so much on travel inside the shock that we use limiters but it doesn't matter how long the rod ends are on the outside of the shock? I must just misunderstand how this works? I thought the limiters to prevent how far the shock can travel? So why allow the a-arms to travel that far anyway by having longer rod lengths?
