Like Tree5Likes
SC10 4x4 Thread
Old 07-22-2011 | 08:05 AM
  #5011
Hey I just got this truck. What's the best motor for a big outdoor track?
AssasinRacing is offline
Old 07-22-2011 | 08:06 AM
  #5012
Numburn's Avatar
Originally Posted by CentralCoaster
Is it the transmission? Remove the spur and bent and see if the trans rotates freely. The case is a tight fit and it can work in your hands but bind up after you tighten the screws and motor plate down. If that is the case back them off a bit and just snug them (with locktite on ones going into motor plate)
Mine has loosened up nicely since, but you don't want all that heat/friction.
I would bet on this. It would be worth slipping your belt off and feeling both transmissions for any binding.
Numburn is offline
Old 07-22-2011 | 08:20 AM
  #5013
^^ Still early on my build, I think I've got the same problem with the tranny. When I turn/spin the shaft by itself after about 4-5 turns it gets really tight then it'll lossen up, after a few turns its tight again...repeat. But when the tranny box is open all the gears turn freely?
GuiltyByAssoc is offline
Old 07-22-2011 | 08:21 AM
  #5014
Cain's Avatar
that kind of sucks that the bags don't have labels on them anymore.
Cain is offline
Old 07-22-2011 | 08:36 AM
  #5015
CraigMBA's Avatar
Totally normal. Run a couple of packs through it and bed in the gearboxes and recheck, but my front one did exactly this and cleared up after I ran it.
CraigMBA is offline
Old 07-22-2011 | 08:44 AM
  #5016
Super! I was planning to spend 1-2hrs just to disassemble the whole thing and start over again. This is my 1st kit ever, I wish the instructions were a bit more clear on some of the installs.
Thanks!
Old 07-22-2011 | 08:45 AM
  #5017
Cain's Avatar
anyone got any recent experiences using the clicker and your opinions on it?
Cain is offline
Old 07-22-2011 | 09:07 AM
  #5018
Cameron Kellogg's Avatar
I tried to use the clicker to help gain more rotation on a tight indoor track. Turned out after a couple of runs a could get my laps up to were I was with it locked. It was better in the sections I was trying to get the truck to turn better on but suffered in other sections. I was having a hard time in the brake zone with it. Locked it back down and changed the rear toe block to a 3-3 and the truck was faster and had the on power rotation I wanted. For me locked it better.
Cameron Kellogg is offline
Old 07-22-2011 | 09:25 AM
  #5019
umm winning's Avatar
drove my sc10 4x4 last night and for some reason i would go into a turn and do a 180, any ideas? running 5k fr 3k r ___ 35fr 30 r for shocks
umm winning is offline
Old 07-22-2011 | 09:39 AM
  #5020
symmetricon's Avatar
First thing i would check is the rear cvas's. sounds like you may have lost a pin in the rear.
symmetricon is offline
Old 07-22-2011 | 09:47 AM
  #5021
Racecrafter's Avatar
Originally Posted by jrusso3
I was wondering if you noted baseline weights prior to centering the battery. Unfortunately I don't have scales here to weigh mine. I'm curious how "unbalanced" the truck is/was in its original configuration or how much it's changed as it sits now.
Found them:
LF 18.9.........RF 20.5
LR 23.1.........RR 25.8
These are the weights from the original configuration with 550. This includes the Rx box and the ESC tray. (They weigh 1.2oz together with bolts.) you can see that even with a 550 this truck is very right side heavy.
Racecrafter is offline
Old 07-22-2011 | 09:52 AM
  #5022
OSherman's Avatar
Thumbs up
Originally Posted by Racecrafter
Found them:
i never would have thought that.. thanks for the info.. time to go remove some counter weight..
OSherman is offline
Old 07-22-2011 | 09:56 AM
  #5023
BlueGlowBoy's Avatar
Or one of the tires is put on too tight, causing a bit of binding on the side that the truck 180s towards.
BlueGlowBoy is offline
Old 07-22-2011 | 10:00 AM
  #5024
Found them:
Was this with or without a battery? It seems odd to me that with the motor on the left side of center, that it would be right side heavy...and I would expect that to be even more exaggerated by a 540, since the weight of the motor would be concentrated more on the right....
Old 07-22-2011 | 10:01 AM
  #5025
Personal opinion: Tekin SC4x 5.5T 550
At least, until we can get our hands on their sensored 4 pole...
But I'm a sucker for smoothness over speed....
