SC10 4x4 Thread
#5012
Is it the transmission? Remove the spur and bent and see if the trans rotates freely. The case is a tight fit and it can work in your hands but bind up after you tighten the screws and motor plate down. If that is the case back them off a bit and just snug them (with locktite on ones going into motor plate)
Mine has loosened up nicely since, but you don't want all that heat/friction.
#5013
^^ Still early on my build, I think I've got the same problem with the tranny. When I turn/spin the shaft by itself after about 4-5 turns it gets really tight then it'll lossen up, after a few turns its tight again...repeat. But when the tranny box is open all the gears turn freely?
#5015
#5018
I tried to use the clicker to help gain more rotation on a tight indoor track. Turned out after a couple of runs a could get my laps up to were I was with it locked. It was better in the sections I was trying to get the truck to turn better on but suffered in other sections. I was having a hard time in the brake zone with it. Locked it back down and changed the rear toe block to a 3-3 and the truck was faster and had the on power rotation I wanted. For me locked it better.
#5020
#5021
LF 18.9.........RF 20.5
LR 23.1.........RR 25.8
These are the weights from the original configuration with 550. This includes the Rx box and the ESC tray. (They weigh 1.2oz together with bolts.) you can see that even with a 550 this truck is very right side heavy.
#5022
Found them:
#5023
#5024
Found them:
#5025
5Likes
