Like Tree1Likes
JP engines
Old 04-30-2011 | 04:27 PM
  #1096
Grinder's Avatar
Originally Posted by TommyBlazin
whats the difference between the 2, runtime etc/ what can i expect, a sirio pipe on a novarossi hmmm? thanks...medium novarossi header im assuming is the ticket?
The SIRIO gives more midrange power, and gets better runtime than the nova 2015. The SIRIO comes with it's own short very conical header.
Grinder is offline
Old 05-01-2011 | 05:08 AM
  #1097
TommyBlazin's Avatar
what do you think of the 2052 i think, the "fat baseball pipe" novarossi? will that be any good with the eagle9? im looking to get at least 5 min runtime...what restrictor do you recommend as well? i have the RX8, so i have to run that stock clutch for now, thinking sheperd spring would be the way
TommyBlazin is offline
Old 05-01-2011 | 01:54 PM
  #1098
I like the 2015 with the 41016 (med) header for the Eagle. Use the 8mm restrictor to start. If you have fuel left over try the 8.5mm. I would also recommend the Nova C8TGH plug for best mileage.
jdesoto is offline
Old 05-02-2011 | 12:55 PM
  #1099
...read down please
Old 07-10-2011 | 03:54 AM
  #1100
Default Need Solid Advice Here
i have a 1 gallon NEW eagle 9, where bottom line piston might not be savagable, i have the best in the buisness looking at it this coming week, question is, since its just the piston, can i get a p/s/r/ set from say a toro nero, or cheaper , and just use the r7 rod and piston and re break new piston into my gallon NEW sleeve, looking for cheapest alternative as this motor is getting to be VERY expensive, i just would love more than a gallon from a 800.00 motor, and i saw novarossi offroad p/s/r/ sets are WAY cheaper, so if im only usuing the piston and r7 rod from the sets, and chucking the sleeves obviouslly would it work? or taking the piston and rod, and sending w gallon old sleeve to be re-sized togther fora new break in? thanks....OR if anyone has just a piston that wants to sell please pm me... desperate here, motor was insane fast, all i tried to do was change rod/wristpin, even sent to a engine modder , and he couldnt get it in properlly as well...any suggestions are welcomed, thanks
tommy
Old 07-10-2011 | 03:21 PM
  #1101
for sale two NIB JP Racing Eagle R-09 Team Edition , $450 each shipped
Roniel_R is offline
Old 07-11-2011 | 06:49 PM
  #1102
SOLOARTIST 702's Avatar
oh boy would love to put that in my stable with the 35 & R03
SOLOARTIST 702 is offline
Old 07-11-2011 | 06:56 PM
  #1103
you never know ,it could be.
Roniel_R is offline
Old 07-12-2011 | 06:16 AM
  #1104
whats the difference between the r09 and the r03/ i have a decent offer on a new r-03 as well, is it a 35plus21 based??etc
Old 07-12-2011 | 07:08 AM
  #1105
The R03 is a 7 port engine based on a 14mm crankshaft, it is basicly a Kangaroo with JP his own specs.
There are 2 versions, the 1st productions had a CNC piston which did not have a long live but for a long time after that it did come with the microcasted piston, you can hear the difference in piston when turning the engine arround on the flywheel. The microcasted piston makes a more cracking sound you should have heard with the R09 as well.
Roelof is offline
Old 07-12-2011 | 08:10 AM
  #1106
yeah i think the R09 is the last of the real jp engines then they go to pop music a little different
Old 07-12-2011 | 11:20 AM
  #1107
Top Belgium driver Robin d'Hondt is running GiMar and I must say these mills are running great.
Roelof is offline
Old 07-16-2011 | 08:41 AM
  #1108
does anyone know the exact size of the front bearing for a jp eagle 9? thanks..also is tko ceramic front or avid ceramic front decent choices? will they not leak etc...
is it the same front bearing as the 35 plus 21?
Old 07-16-2011 | 09:11 AM
  #1109
No the 35plus uses a smaller front bearing. Here are the part#s for the Eagle:
front 17003
rear 16002 or 16001 if you want to save $$
desotoracing is offline
Old 07-16-2011 | 09:39 AM
  #1110
I want the best front bearing i can install
