SC10 4x4 Thread
#4052
ThunderbirdJunkie will continue to use them as uptravel limiters until they fall out. He hates unscrewing shock ends
Question:
Has anybody successfully bolted a 1/8 motor into one of these?
#4053
#4055
I was having the crunching noise after my build coming from the rear diff/rear slipper area. For 4 days sitting on the stand after putting in the electronics&I could not figure out what it was. It would make the sound as I accelerated on the trigger.
I took apart the whole rear of the car and took apart the diff. Everything seemed fine, so I put everything back 1 screw at a time, while running the motor connected to the slipper/diff, to see if the noise continued. After the whole process the noise went away&it sounded fine. I never found out what the noise was, but i figured it was binding of the rear transmission.?.? So i am keeping all the screws holding the rear diff/motor plate snug only/not tight!!
U definitely have to take the rear apart&rebuild it.
GL
THX
GL
THX
#4057
outdrive wobble, it's simply in the design IMO, not on purpose for sure but the outdrive has an o-ring in it that rides IN the bushing in the diff. Personally I'm not going to try and get rid of the wobble ATM. If I see a huge wear isssue over time on the diff gears then I'll worry about it...
Tolerences can only be so tight when you run an o-ring on a shaft IN a bushing, especially with stuff this small..
becouse the wobble will be there with stock setup aswell. so it is a design flaw.
I also leave it for what it is. but because of the wobble I need to refill the diff much more often, and that is not a easy task
#4059
GL
THX
GL
THX
Your SOUND could have been one of the screws holding the motor plate onto the rear diff, binding on the slipper just a little bit.
the first time i put mine together, i had mine too tight and it wouldn't move without some loud noises, i loosened the slipper off. looked at the metal pad and saw a gouge in it, so i put the screw in looser and its all good now.
Could someone please explain to me how adjusting roll centre fixed the trucking wanting to traction roll on fast sweepers.
Would i just add roughly 3-5 mm spacers under the inside camber links front and rear.
could i also stand my shocks up a bit. to allow them to have more leverage on the arms.
any help would be appreciated. If you could please pm me a response that would be better, as its a little hard to check this thread often.
thanks.
#4060
I guess lack of sleep makes ya loopy. it was my pinion gear.
I fixed it but I still hear it skip a couple teeth. The mesh is hard to set, 1 too hair close and its binding. Oh well for the most part problem is fixed. Now to have fun with this thing!
#4061
I have the 1415 in which is more than enough power and you can still move for pinions
#4062
#4063
So I am looking at getting one of these. Everyone at my local track has the Losi, and I want to be different. Has anyone noticed and major wear items yet, and what has a tendency to break first? Also has anyone had a hard time getting a 550 motor to fit in the truck? Also would their be enough room on the electronics tray to make a RX8 fit without any problem? Thanks for the input!!
#4064
#4065
This was the only problem found, Shes a keeper.
top shims are from front diff, 2 damaged ones are rear.
5Likes
