IDM Products?
Old 06-24-2011 | 09:25 AM
  #676
quietstorm76's Avatar
Originally Posted by MugenDrew
Attachment 772079
Hey Mr. Moten look what I got.
Nice!!! I'm jealous
quietstorm76 is offline
Old 06-24-2011 | 12:07 PM
  #677
GMartinez's Avatar
Originally Posted by quietstorm76
Nice!!! I'm jealous
Don't worry about him only 2 things can happen when he runs it think of a pinball game
GMartinez is offline
Old 06-24-2011 | 12:21 PM
  #678
MugenDrew's Avatar
LOL, not only did I out qualify you by 7 positions last race at YOUR track. You broke in the main before I did and I've got all summer to practice.
MugenDrew is offline
Old 06-24-2011 | 12:30 PM
  #679
GMartinez's Avatar
1 race & miracles do happen & be specific
I did not break I dnf due to stripping gears but a win is a win & what happened to u in the main u only did 23 laps
Old 06-24-2011 | 02:10 PM
  #680
Attachment 772079
Drew 600 cc for break-in at 200-220
Jim
jrice is offline
Old 06-24-2011 | 03:11 PM
  #681
Grinder's Avatar
Attachment 772079
We have one RCW .21 IDM still available. Get it factory tuned, or Murnan Modified. We also have the newest IDM .12's available. Stock, or Murnan Modified versions. The modified .12, and .21 are absolute screamers.
IDM .12 pipes are also in stock.
Grinder is offline
Old 06-24-2011 | 04:08 PM
  #682
WOW!!!!
ShepherdAmerica is offline
Old 06-24-2011 | 04:15 PM
  #683
GMartinez's Avatar
Originally Posted by ShepherdAmerica
WOW!!!!
2 much power
Old 06-24-2011 | 04:46 PM
  #684
MugenDrew's Avatar
2 much power
Yeap sounds about rite...
Old 06-29-2011 | 06:07 AM
  #685
Anyone use Novarossi plugs on the newer motors. .12?
JETT is offline
Old 06-29-2011 | 10:07 AM
  #686
You cannot use a Nova plug in the IDM engine. Reason is listed below for reference.
The plug will thread in but the taper of the turbo seat is wider then the IDM taper. So you will damage the combustion chamber when you tighten it down. Just will not seal proper and distort the origional taper.
xspower is offline
Old 07-20-2011 | 07:28 AM
  #687
MugenDrew's Avatar
Well ran the engine(RCW) last weekend. WOW. YES it's fast. YES it has a ton of bottom end. Enough bottom end that during the second qualy my transmission started "blowing up". The first gear one way bearing had pushed itself out of the housing 3mm forcing it into the face of second gear by the end of the main.
I am amazed at how quick and fast the engine was the hole main with this going on. I am also very surprised I did not strip a gear.
With this going on it was easily on par with my XXL9 Tq's. The throttle feel of this engine is something that has to be experienced, dare I compare it to an electric mod??? No more wiz BANG!
With .4mm worth of head shims, #7 IDM plug, 2033 pipe, 9mm restrictor and 20% Byrons I found out by accident when my pit guy ran me out of fuel in the main that my run time was about 5:40.
It will be about a month before I will be able to run it again and I am already chomping at the bit.
Want the simple...yes it
!!!KICKSAZZ!!!
Old 07-21-2011 | 07:19 AM
  #688
Grinder's Avatar
!!!KICKSAZZ!!!
Yep. They are great engines.
Grinder is offline
Old 08-08-2011 | 06:44 AM
  #689
Default IDM evo 4 3.5cc
Hi... Just came back from the nationals... Engine was running flawless on sat practice and Sunday qualifying.... Came final engine running was not touched since sat. The engine flamed out twice in the my final. Restarted it with the same plug and it finished the race. Anyone experienced this situation or know what the problem is ? The plug was at it optimum by looking and no marks on internal. Top of piston golden brown colour only at center of the piston. Hopefully that rules out lean running.
xtreme888 is offline
Old 08-08-2011 | 07:03 AM
  #690
roger999's Avatar
hi, currently using OS plugs on my Picco .12 evo4, what else i can use? Just in case i can't find OS plugs...
roger999 is offline
