#5326
Marko, remember Andy was saying on Sunday about how each time you switch the unit on the sensor re-calibrates. Maybe it needed some heat in the unit??? Anyway, so long as it's a sensor thing that's ok.
#5327
Angelo, could you re-post that list of sellers in HK selling fake Hobbywing products for us all?
#5328
It would appear that everything is pointing to a sensor lead fault.... I will change this and test it.
BUT why after it has only been turned off and on would it run faultlessly for 5 mins ? surely if it was a dodgy sensor lead it would drop into sensorless mode with no timing mid run ?
Mark
Mark
would be handy thing to have
pleeeeeeeaaassee
#5329
Dear Sir,
Sure I used Mod. firmware in that case. No abnormal heat or sound before they dead. And after that issue happened no burning smell came out. Also we have checked all the running parts in our car are smooth without knocking. For the motor , battery and also sensor cable were in good condition.
However, they are sent to service centre for repairing now. We use them for not more than 2 months.
I just need to know what is the casue of that fault and it can let us know how to prevent the same issue happen again.
Thanks all!
Thanks all!
#5330
Dear Sir,
Thanks all!
Thanks all!
Your esc might not be dead electrically but might be dead in the firmware .We had an issue a while ago with the flash memory being wiped and all the factory settings were cleared of the flash memory.
Does your esc power up ?when plugged into the 2 in 1 programmer does it state connecting to esc but doesnt move off that screen?
I need some more info from you and then i can help you by saying its dead means nothing i need more symtoms of what the esc is doing and not doing .ok
regards Angelo
#5331
Hi,
just wondering if i would need to run a fan on the hw 120a esc,running a X12 17.5T,with boost etc?
thanks simon
thanks simon
#5333
Hobbywing in the UK
Hi Guys, just to let you know our latest shipment is in. The Black 1s ESC (Which needs no booster battery etc) and our Black 120Amp V2.1 are back in everything else is due by end of next week.
Until the 21st June we are extending the Pre Order Discounting for in Stock units with free shipping, oh and don't forget the 'cherry' voucher code for an ADDITIONAL Discount !!!
http://www.racersinexile.org.uk/XERU...0_2127148.aspx
http://www.racersinexile.org.uk/Hobb...0_3754996.aspx
Cheers all !!!
Cheers all !!!
#5334
Hi guys what settings to run on stock spec speedo with an x12 13.5?
small and technical track.
Cheers Ricky
Cheers Ricky
#5335
After running for about 2 mins it stopped suddently no running but the servo
Can move only, green lamp blinking. But after sw off and on, no light or running even moving the throttle. Connected to programme box, it showed nothing and only the version of the box only.
Hope those inf can help u to find out the reason of the fault.
Thanks!
Hk Rc player
#5336
Hi! Angelo,
Thanks!
Hk Rc player
Thanks!
Hk Rc player
#5340
What are the advantages of running the 4 caps instead of 2. If it's to get better brakes then I don't need them as the extreme locks the wheels on my tc. Is there any other improvements from running them.
Thanks jay
Thanks jay
