NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE
#6076
I'm not so sure but i think when i plug the program box to the speedo that shows me the esc settings and not the profile settings saved on the program box.I don't know if you understand what i mean.
#6077
So, for each one of your program, you need to send it to your speedo.
When all 3 are in, unplug the compy usb link and switch 2.1 box, it will come up with the version, press item, the first setting will show up, press R/P button (you might need to do it twice) then press value, the software name will come up then your profile, press value again and second profile will show the value again to go to third and so on back to first.
#6078
No,no.I'm talking for the same software (211) but different saved profiles on the program box.For example if i have on my esc the settings for my 10.5 motor and i switch to my 8.5 motor,how i could load the already saved profile for the 8.5 from the program box to the esc?
#6079
regardless of the version, yours 211, mine 224 etc...
when this is done, unplug usb cable, switch ESC off and back on and follow previous post.
#6080
But here is what you should do:
connect the ESC to the program box.
Plug the ESC into your drive battery.
switch on the ESC, the programbox will show the current firmware version it has.
Press the "ok" button, it will connect to the ESC, and show the ESC firmware version and jump into the last used profile.
No press the "r/p" button, you will see the current profle and with the "value" button you can select another profile. Finally with the "item" button you can get into the profile.
#6081
Well,i'll try.Thanks guys.
#6082
USB link Software Last update (11/8/31)
#6083
#6084
The profiles are saved in the ESC...
Have you tried to save different software versions too, it looks like for each profile it shows the soft version, might give it a go, would be good to have to switch from X12 to other motor. (224/211)
#6086
TBH I didn't connect my ESC, but I read the "CAR_ESC_version_control.ini"
which is in the installed program folder...
#6087
You can only save 3 different setting, but all 3 under the same firmware version.
But if you manage it, tell us how you did it!...
#6088
#6089
Xerun 3.5T gearing
The XXX-S is currently fitted with an 88T spur gear. The diff ratio is 1.83:1. We have no pinions and intend to order a couple of different sizes to try. We have not yet received the HW 120A ESC / 3.5T motor.
A safe starting setup (gearing and ESC) for an extremely large flowing track would be appreciated.
#6090
which software??
hobbywing 211 or speedpassion that updated in may on their website?? i've got an xtreme stock hobbywing ESC!! where can i found the latest software for hobbwing? which are the best program running on 17.5t? sorry guys but i'm really new to eletric on road
