Like Tree5Likes
SC10 4x4 Thread
Old 06-18-2011 | 06:34 PM
  #3361
seniorskywalker's Avatar
Originally Posted by Matt Howard
I tried my tekin 7.5 540 motor with a 13mm rotor in it today and holy cow, I'm sticking with this combo. Same lowend torque as my LRP 5.5 550 motor, more top end, and ran cooler. Hottest it got was 145 all day long and the battery was only taking back in between 1600 and 1700 mah after a 6 minute run on our indoor track.
this surprises me. not about the torque or top end but that temps went down. I run a lrp 540 8.5 w/ 13mm rotor on tight indoor track. after 5 min temps at 180+. what is ur gearing?
seniorskywalker is offline
Old 06-18-2011 | 06:39 PM
  #3362
Matt Howard's Avatar
18/93 with 4 deg of motor timing. I was expecting it to run hot as well but it never got over 145-150 deg.
Matt Howard is offline
Old 06-18-2011 | 06:46 PM
  #3363
ilanstylz's Avatar
I'm curious as well, cause I ran my 540 sensored motor with similar gearing and I burned up the motor lol......
I was wondering are you running with clicker on or off?
I don't know if its just me but it seems like my motor ran hotter with clicker off, probably around 10-15 degrees more then with clicker on......
ilanstylz is offline
Old 06-18-2011 | 06:48 PM
  #3364
clicker locked
Old 06-18-2011 | 07:29 PM
  #3365
jwood7's Avatar
Originally Posted by Chuck 21
Heres your problem with your slipper.
#1 you put the washer under the wrong end of the spring.
Take your slipper spring off and look at the shaft. You will see the shaft
has a cone tapper just before the threads. Looking at this you will see the
spring retainer bottoms out against the cone before you can get max
tension against the slipper. So putting it at the wrong end as you did makes
the problem worse. The washer needs to be on the aluminum slipper plate
not the nut end.
So what I did was go to Ace Hardware in their nut and bolt department
they have a chrome & black chrome nut/bolt/washer section. There is a
chrome & black chrome washer there that fits the outer slipper hub
perfectly for shimming the spring. Take your outer slipper hub with you
because thanks to the chroming prosess some fit better then others.
Now you will keep your slipper spring free to put max tension against the
slipper pads instead of making the problem worse like you did by putting
the washer under the nut.
This works great, I have fixed many SC10 4x4 slippers at the tracks I race
at this way. At the track I don't have these washers with me but a quick
fix at the track is to take the blue aluminum servo arm retainer that most
people have laying around in their tool box and use that till you can get to
Ace Hardware to get the correct fitting washer.
Good luck, I hope this helps till AE gets this fixed along with everything else
they need to fix on the SC10 4x4....
BTW: AE if your listening, you need to make a longer & stronger slipper
spring for the SC10 4x4 (I'm sure you know this already though")
I tried this last night on a tight indoor high bite track and it works, to good in fact I roasted a spur gear cause I had it too tight
jwood7 is offline
Old 06-18-2011 | 08:01 PM
  #3366
has anyone found a set of sway bars that work that dont have to be home made?
SHAUN GRIDER is offline
Old 06-18-2011 | 08:04 PM
  #3367
ilanstylz's Avatar
The losi 8ight swaybar set will fit, its what I have on my sc10 and you can get the set on ebay for 10 bucks.......
Old 06-18-2011 | 08:50 PM
  #3368
jpure009's Avatar
What is the size in mm, is your thrust spacer? if u don't mind measuring for me. The measurement of just the part that spaces, the part that fits into the slot, i believe won't matter.?.
What size washer(s) did u use?? And, How many?
I will run mine Monday, before I know for sure if I need it. So, if it's slipping too much I will need it?? I would like to just know the measurements the thrust spacer is suppose to be so i can know if I need washers or not.
But, basically i need to know how thick i need to make the thrust spacer/washers??
Fast, wrote 2.90mm, so i guess that is how thick it's suppose to be.?.
THX
jpure009 is offline
Old 06-18-2011 | 09:03 PM
  #3369
T-BirdJunkie's Avatar
OK, so it seems something is definitely wrong with ThunderbirdJunkie's SC10 4 wheeler.
Battery just took 38xx mah, charging after last night's main. That being said, there was about 5 minutes of screwing around afterwards, but 12 minutes to put that back in a 5000mah battery, while when the truck was fairly new it ran 23 minutes and was cool as a cucumber.
It came off the track with the 1410 at 160 (acceptable, but not ideal considering the 15/62 gearing) and the speedo (Mamba Max) was a smoldering 209 after the first 5 minute heat. Since it got cooler as the night went on, it wasn't so bad later, but the speedo was still in the 180s and the motor in the mid 150s.
Belt's loose, when there's no pinion on it the truck rolls nice and smooth...ThunderbirdJunkie is ripping his hair out trying to figure this out.
T-BirdJunkie is offline
Old 06-18-2011 | 09:12 PM
  #3370
ilanstylz's Avatar
Maybe you did something to the diff's since you've changed the fluids on them so many times lol...... Iono do you have another esc you can test out and check if its just the esc getting old?
Old 06-18-2011 | 09:29 PM
  #3371
I'm at a loss here. I'm running 17/93 with no motor timing and a tekin rs with no timing advance. been debating on switching to 550 for this very reason. (overheating) waiting on tekin 4-pole motor right now as I am not a cc fan. don't like run times with 550's and don't need any more power.....but its just too hot right now. drivetrain is free...no binding... any thoughts?
  #3372
Uh...just a Mamba Monster. Not sure that sucker will fit
Old 06-18-2011 | 09:30 PM
  #3373
ilanstylz's Avatar
Sure it will , just mount that sucker on top of the drivebelt cover ;-)
Old 06-18-2011 | 10:13 PM
  #3374
Aoh
they are in stock at stores. i just got F&R set from http://www.westcoastrcraceway.com/
Aoh is offline
Old 06-18-2011 | 10:17 PM
  #3375
Eli's Avatar
Eli
Heard it from tekno himself and am now confirming it(have a set in hand) the aluminum hex's part number tkr1654x are now coming with pins and shims so it looks like everything you need. GO TEKNO!
Eli is offline
