Like Tree5Likes
SC10 4x4 Thread
Old 06-14-2011 | 03:33 PM
  #3211
Originally Posted by 1Fastpede
i do use green slime and the gasket doesn't leak.. its leaking via the out-drives.
Have you tried green slime on the o-rings that the outdrives slide thru? I was going to do this to my diffs last time i pulled them but got lazy...
Keeferton is offline
Old 06-14-2011 | 03:34 PM
  #3212
Sent you a pm.
Super Coupe is offline
Old 06-14-2011 | 03:59 PM
  #3213
Cameron Kellogg's Avatar
You can use the gear diff seal kit from the SC10 RTR for the outdrive seals. AE #9831
Cameron Kellogg is offline
Old 06-14-2011 | 04:15 PM
  #3214
1Fastpede's Avatar
yes I did, didn't help. i even rebuilt them with new orings. still leaky leaky
1Fastpede is offline
Old 06-14-2011 | 04:34 PM
  #3215
Originally Posted by JEFFs SC10
can you grab a pic of your fan setup? any vids of you racing? good job racing!
http://www.rctech.net/forum/9215010-post2861.html
Here is the post of my fan set up.
There is only one video with my truck running in a Video from NW SC Nationals. You see me for a few seconds when I pass Maybell for 2nd. Then I am gone again. ...
Old 06-14-2011 | 07:06 PM
  #3216
dagsom's Avatar
Originally Posted by dagsom
People with a Tekin SC4X 4.5... what motor temps are you getting? With what gearing?
I think my motor was getting hot (150-158) from the belt being too tight. Im going to loosen it up and see if it helps any.
dagsom is offline
Old 06-14-2011 | 07:33 PM
  #3217
Do you think you need to replace the diff halves?
Old 06-14-2011 | 07:34 PM
  #3218
symmetricon's Avatar
Sweet, ran my truck to test the shocks with some of Mantiswork's custom pistons and they felt amazing. Im not sure what oil wt was in it, but the truck felt so good. since I am waiting for some different o-rings, and the stock ones arent the greatest, he put some caster o-rings he had on hand. with the custom pistons the rebound rate was so much improved, the truck looked as if it was gliding over the ruff parts of the track.
symmetricon is offline
Old 06-14-2011 | 07:40 PM
  #3219
Any pictures of these pistons?
Old 06-14-2011 | 08:06 PM
  #3220
I can post some pics, but need to check w/ Mantisworks. ill put up the picks tomorrow if he is ok with it.
Old 06-15-2011 | 03:57 AM
  #3221
racene1's Avatar
Originally Posted by racene1
Same thing happened to me, (the binding) I think what it is is the front of the belt, you know around the clicker, is either twisting or hopping up on the outer rail and binding up on the plastic cover. How often is the belt supposed to be changed?
THanks, JT
Just like a real car. The last time before you drove it and it broke.
True, but really, Is there a half life for this thing?
JT
racene1 is offline
Old 06-15-2011 | 04:21 AM
  #3222
I ran mine at our recent state race with a 12tooth pinion. After a 10min main plus a couple practice laps mine came off the track at 165 degrees. It was a very hot day though.
grubster is offline
Old 06-15-2011 | 06:35 AM
  #3223
Suspended
hey guys do any of yours know what gear and pinion i should be running in my sc10 4x4 with a venom brushless combo 120 amp esc and a 3.5t motor
zenbonzakura is offline
Old 06-15-2011 | 06:51 AM
  #3224
1Fastpede's Avatar
I hope not I used brand new diff halves..
Old 06-15-2011 | 06:53 AM
  #3225
Has anyone had trouble taking their body from the 2wd SC10 and putting it on the 4x4? I know it is supposed to be a direct fit, but mine is not. Do you have to raise the body mounts from the stock position? Mine hits the bumpers in the front and rear and the holes in the body are slightly off. Any suggestions? THanks
MitchFX is offline
