Like Tree5Likes
SC10 4x4 Thread
Old 05-24-2011 | 06:16 PM
  #2101
CentralCoaster's Avatar
The clicker doesn't seem to have much adjustment...
Seems to go from loose to pretty loose, to locked. I think a stiffer spring would allow you to run it tighter before it locks up. I'm not sure if it would be able to handle the extra abuse, but it would be cool to have a little bit of front braking with it partway in.
CentralCoaster is offline
Old 05-24-2011 | 06:23 PM
  #2102
I didn't have issues neither. One thing I've noticed with kits that are having issues are from guys who build it in 2 to 3 hours, I took my time read and re read the directions till I knew exactly what to do then did that step, I then checked over everything after each step to make sure nothing was binding.
So I'm a nut shell rush and have problems, take your time and reduce problems drastically
Mike_Shepard is offline
  #2103
SaladFork's Avatar
Originally Posted by CentralCoaster
I have never used/needed expo, I would not say it's critical.
It would be if you are looking for expo adjustments. But in a pinch and on a 35 dollar remote, expo would be my last worry.
SaladFork is offline
Old 05-24-2011 | 06:32 PM
  #2104
RodneyB's Avatar
Originally Posted by kdeselms
Is it worth waiting for a new round of kits, so that AE can get some of their parts issues straightened out? I have been following the thread off and on, it seems like there have been a lot of issues with things not being machined correctly or pieces missing, etc... I'd like to get one, just a bit tentative with all the reports of various parts issues and the need for do-it-yourself fixes.
I for one am shocked at the relatively few problems people have had with this new ground up design and with how few broken parts have been reported. I certainly expected more issues. My only problem was that I had to make my own swaybars, which made this truck go from good to great on the track.
RodneyB is offline
Old 05-24-2011 | 06:35 PM
  #2105
MistermomHB's Avatar
Originally Posted by BoneDoc
Keep in mind that myriads of SC10 owners without issues don't post about our "non" issues. Everything was perfect on my kit. If you can find one, go for it.
+1
MistermomHB is offline
Old 05-24-2011 | 06:39 PM
  #2106
Have you guys tried running the 19T clicker in the front? If not, try it. I'm liking that (I think) it reduces some of the oversteer on power.
Also, I switched from 30 to 35 wt oil in the front ... LOVE IT. Now it doesn't bounce around nearly as much on jumps or big bumps. Instead, the shocks now just absorb the bump, and keeps on going.
... also for a lot of people, it's a great idea to play around with the expo (just make sure that you've got it in the CORRECT DIRECTION: Negative for hitec / futaba, and positive for spektrum / JR .. and I think Airtronics). It allows us to to keep the steering, yet making the small input much more easily done, as well as making it less likely to spin out. My guess is that those who said that they don't need it are part of the old school crowd who learned on NO expo .
BoneDoc is offline
Old 05-24-2011 | 06:41 PM
  #2107
Most of the adjustment on the clicker happens in the first turn from completely locked. So try locking it all the way, and then turning it 1/8 to 1/4 turn at a time.
I can get mine to stay locked except in really hard braking. Adding the black grease (per Chris Jaroz's recs) also help reduce the annoying sound )
BoneDoc is offline
Old 05-24-2011 | 06:50 PM
  #2108
Cameron Kellogg's Avatar
I would like to see some different tension clicker springs like we have for shock springs. Seems you get a easy click or locked with the stock spring. I would like to be able to adjust how much click; more that we can now. I used some pretty heavy grease to make it quite and help slow the click some.
Cameron Kellogg is offline
Old 05-24-2011 | 06:56 PM
  #2109
We put my friends truck together the other day and it was flawless. Starting on mine tOmorrow.
Super Coupe is offline
Old 05-24-2011 | 06:57 PM
  #2110
symmetricon's Avatar
I have built two kits with zero problems. Ive had mine at the track 4 times(probably 40 packs) and have broken nothing. I just finised building Sam's kit (you know who I am) and it went flawlessly. In fact, it was a pleasure building them both
symmetricon is offline
Old 05-24-2011 | 06:58 PM
  #2111
we had 20 kits, one was missing one part and we sold 18 kits so far...... that is a great percentage!!
Team T2C is offline
Old 05-24-2011 | 07:01 PM
  #2112
After driving one my truck will have the clicker locked. The truck turns insanely good. I don't much need for it unless you have a very very small tight high bite track.
Old 05-24-2011 | 07:06 PM
  #2113
kromesoldier's Avatar
the only problem i found was the shock piston screws. the kit went together perfectly. all the parts were there. nothing screwed up. i gotta say, for a new design its pretty tough.
kromesoldier is offline
Old 05-24-2011 | 08:28 PM
  #2114
Farmer_John's Avatar
Originally Posted by jammintosc104x4
this is the sway bar kit for he jammin no mods... post #1950
From the Jammin SC truck? Part number please!
Farmer_John is offline
Old 05-24-2011 | 08:33 PM
  #2115
Yeti AS3's Avatar
I ran my clicker tighter than 2mm but not quite 3mm. It was a lot tighter than the 2mm setting. I completely roached the clicker in a few heats. My guess is the excessive friction was too much for it. I didn't have any black grease on it.
Yeti AS3 is offline
