Like Tree5Likes
SC10 4x4 Thread
Old 05-23-2011 | 09:32 AM
  #1951
CentralCoaster's Avatar
Originally Posted by T-BirdJunkie
Dude, honestly, did you pay somebody else to build the truck for you? It's a 6mm axle. Says so right in the instructions when you're assembling the CVAs and putting bearings in the carriers.
What's with the attitude? This a tech thread, not a Jerry Springer thread.
CentralCoaster is offline
Old 05-23-2011 | 09:36 AM
  #1952
Originally Posted by ktm11rider
Just took the shocks apart for the first time and tried to follow the associated video on how to build them emulsion style. When i take the bladder out of the shock i dont see any o ring in the cap like he says in the video. And sorry for the dumb question but if there is a bleederscrew hole why is there a little hole under it too. It leaks out of there. Not good with shocks only have built a couple before. Please fill me in
The emulsion orings were in the shock parts bag and go in in place of the bladders.
The little hole is for bleeding shocks with bladders. You can't bleed out the top hole because the bladder would block the fluid path and just balloon out.
Old 05-23-2011 | 09:58 AM
  #1953
MarqueeRc's Avatar
Originally Posted by symmetricon
Mine did not come with any exra hardware for the /slipper assembly. Nor have I had problems. But I can take mine appart and check the thikness of the slipper thrust spacer. It might be a good investmesnt to get the high torque slipper pad aswell.
Ill post the measurements in a bit.
Here you go Marquee,
and the washer
ID of 6.02mm OD 12.18mm 1mm thick
If your slipper thrust spacer is thinner, than I would suggest finding some 6mmX1mm think washers and try adding them to the outside of the slipper thrust washer.
Hope this helps
Thank you Symmetrcon!!Very useful and helpful info!
MarqueeRc is offline
Old 05-23-2011 | 10:01 AM
  #1954
MistermomHB's Avatar
Originally Posted by Ridge Runner
Just wondering why everyone wants to know what different wheel will fit the truck? Is there something wrong with the stock wheels? Is there a problem mounting different manufacturers tires to the wheel? Just curious because I am going to load up on a variety of Proline tires and if there is no problem with the stock wheels, Associated's stock wheels are what I will buy instead of having trouble fitting other wheels.
Pro-Line 272300 ProTrac Susp SpltSix Whls Fr,R:SLASH
MistermomHB is offline
Old 05-23-2011 | 10:26 AM
  #1955
JayL's Avatar
the DE wheels for SCTE are about 2mm narrow compared to the stock AE wheels, FYI in case you read that they fit/work. they do but you lose width. That must be why DE said they are making an sc10 4x4 specific wheel
JayL is offline
Old 05-23-2011 | 10:27 AM
  #1956
1Fastpede's Avatar
also seeing a bunch of slash wheels on some local SC10 4x4x's and they stick out past the body. good for club racing but good luck at an event.
1Fastpede is offline
Old 05-23-2011 | 10:33 AM
  #1957
T-BirdJunkie's Avatar
Originally Posted by RC*PHREAK
i believe it tells you in the manual how to set the slipper...
yup. page 28.
It tells you how to install it. It doesn't tell you about setting. It just says "tighten if clutch slips excessively while driving" and tells you to set the nut with 3.5mm of threads sticking out past it.
Maybe that's why ThunderbirdJunkie's truck looks a bit narrow with the SCTE wheels on it.
Good to know
Can't wait for DE's wheels!
T-BirdJunkie is offline
Old 05-23-2011 | 10:41 AM
  #1958
Dusttt's Avatar
so are you saying these are 2mm narrower too?
http://prolineracing.com/wheels/prot...-piece-wheels/
my DE wheels seem fine. Anyone have pics with a caliper comparison of both?
Dusttt is offline
Old 05-23-2011 | 11:09 AM
  #1959
The Pro-Trac wheels are fine for width - but the Slash Rear offset wheel will stick out of the body -
Alex.Eklund is offline
Old 05-23-2011 | 11:15 AM
  #1960
sand viper's Avatar
Hey again guys, im having a bit of troubles still with the trucks setup. Now i run on mostly dusty 1/8th tracks, and currently my setup is:
30 weight in the front-no rebound-bladders
25 weight rear- no rebound- bladders
over drive in the front
stock ride height, but lowered in the back to make equal front to back.
5mm washers under the front ballstuds
And im running m2 calibers all the way around.
Now the truck is quite good, but still fairly loose in the rear. On long sweeping corners it wants to drift out, and sometimes on the tight corners too, if i get too carried away with the throttle.
Anyways i was just wondering if this can be fixed or helped any further? It just seems like the truck has way too much give in the back.
sand viper is offline
Old 05-23-2011 | 11:23 AM
  #1961
JayL's Avatar
I did not measure the hex offset.
I just set the rims on my setup board next to each other on the side, de scte and stock sc10 4x4 and the de rim itself is more narrow. they may stick out the same due to offset.
JayL is offline
Old 05-23-2011 | 11:27 AM
  #1962
FrancoisTX's Avatar
Originally Posted by racer1812
AE spoiled perfection because they made the 4x4 body mounts the same as THEIR 2wd truck and not for your Smash body..
slap slap
You know what, I have Caliber M4 at all corners and I have exactly the same trouble.......Maybe Caliber at rear is not perfect. I ll going to try bar code, I ll post about that when the test will be done, friday
FrancoisTX is offline
Old 05-23-2011 | 11:30 AM
  #1963
I just went and hit my AE & DE wheels with my digital caliper and the DE
SCTE wheel is 1/2 mm narrower off set then the AE wheel so that makes
the SC10 4x4 a total of 1 mm narrower with the DE SCTE wheel.
Heres the funny thing I noticed while I was checking them out: The AE
wheel is 1 mm wider where the tire mounts then the DE wheel. The AE
wheel has the outside bead of tire 1 mm out farther then the DE wheel
does. So if you look at it with this in mind the truck will be 6mm over all
narrower with the DE wheel the the AE wheel.
So then I put both the AE & the DE wheels on the SC10 4x4 and the over
all mesurement was 3 mm wider with the AE wheel then the DE wheel. So
even though the inside offset is only 1/2 mm between the two wheels if
you mesure them on the truck the extra width of the AE wheel ends up
giving you a 3 mm wider truck the the SCTE DE wheel does. I'm not sure
this will make a whole lot of difference in the way the truck handles, but
I could wrong"
Sorry, no pictures as I have no idea how to post pictures.
Chuck 21 is offline
Old 05-23-2011 | 11:35 AM
  #1964
Racecrafter's Avatar
Edit: I give up.....
Racecrafter is offline
Old 05-23-2011 | 11:39 AM
  #1965
Me too LOL"
Chuck 21 is offline
