Like Tree5Likes
SC10 4x4 Thread
Old 05-22-2011 | 08:25 PM
  #1906
DRRC's Avatar
Here is my sc10 4wd with a Jconcepts body
Novak GTB with LRP 540 6.5
custom made 2.0mm swaybar (not in pic) which should make the car easier to drive
Attached Thumbnails SC10 4x4 Thread-img_2611.jpg   SC10 4x4 Thread-img_2613.jpg
DRRC is offline
Old 05-22-2011 | 08:31 PM
  #1907
Wolf1007's Avatar
Default Shock Setup?
Guys,
Half rebound on all four shocks or just the fronts? The setup sheet in the manual only says half rebound for the fronts and is blank for the rears?
Can anyone clarify for me? Thanks!
Jim
Wolf1007 is offline
Old 05-22-2011 | 08:38 PM
  #1908
Sideways_1's Avatar
Originally Posted by Sideways_1
Anyone had any trouble with the shock bladders? I have 2 with pin holes in them and they all seem hard and brittle. This is a new build with 0 runtime on it.
Anyone?
I did build them both at Half Rebound just to start with, which is when I found the above issue.
Sideways_1 is offline
Old 05-22-2011 | 08:50 PM
  #1909
ktm11rider's Avatar
Just took the shocks apart for the first time and tried to follow the associated video on how to build them emulsion style. When i take the bladder out of the shock i dont see any o ring in the cap like he says in the video. And sorry for the dumb question but if there is a bleederscrew hole why is there a little hole under it too. It leaks out of there. Not good with shocks only have built a couple before. Please fill me in
ktm11rider is offline
Old 05-22-2011 | 09:04 PM
  #1910
socalrcer's Avatar
Originally Posted by mxracer458
So is everyone running a 550 or 540 can motors?can you run a
Tc spec with a 550'can or should you just run the rx8?
I am running a TC Spec Ver. 2 with an Icon 4.5 550 and it runs awesome. Very smooth. Speedo is about 120 without the fan and 86 with the fan. If you don't have the Ver 2 you might still be able to trade up with LRP. Gearing is 12/62 32 pitch. Running at West Coast RC indoor, clay track. Check out LiveRC if you want a feel for the size.
socalrcer is offline
Old 05-22-2011 | 09:14 PM
  #1911
BLbound's Avatar
Originally Posted by HarleyGuy
Secondly, I aligned my servo (Savox SC-1256TG) during building, but as I was driving I noticed that my truck kept pulling to the right... I would adjust the trim and it would be good for a few minutes then start pulling again... In the end I had the trim set 100% to the right... Anyone had an issue like this??? If so what was the cause?
Thanks for the help,
Shane
This is my problem too...I raced mine for the first time yesterday and I had my servo always wanting to veer to the right or left. I'm wondering if my servo has just gotten old and tired (it was doing steering duty for a kyosho st-rr for a while)? Today I could center the servo & checked it in front of my house...I would go up and down the street a little and come back & it would be off center again! I haven't pulled off the servo arm yet to see if it's the arm...I hope I don't have to buy another servo...I didn't crash enough yesterday to warrant it, but then again it maybe that it's just old and has lost it's centering ability? A few people have posted this same problem...have you guys fixed it? Please let me know...thanks!
BLbound is offline
Old 05-22-2011 | 09:17 PM
  #1912
MistermomHB's Avatar
Default sway bars SC104x4
I see all over the forms people asking about the sway bars. They help I race at a high traction clay track. The set up with sway bars is working for me, after a week of tuning. Ok the setup that works for me "now" (time is the only constant.) 10,000w front diff and 40w front shocks, 3k rear diff 37.5 rear shocks, the sway bars mounted no mods from my jammin. front sway 1.5mm rear is 2mm. I hope this helps someone...
Sportsman 4x4 SC WCRC
JamminToSC104x4 and lovin it.
Attached Thumbnails SC10 4x4 Thread-mail.jpg   SC10 4x4 Thread-mail1.jpg   SC10 4x4 Thread-mail2.jpg   SC10 4x4 Thread-mail3.jpg
MistermomHB is offline
Old 05-22-2011 | 09:29 PM
  #1913
lockmouth's Avatar
The seals for the emulsion set-up are in the bag with the spare pistons and up travel clips.
lockmouth is offline
  #1914
Default Bladders
Anyone?
the shock build video @
teamassociated SC10 4x4_Shock_Build video (lol can't post a link, new member)
No rebound and no bladders works well for me. The o ring came in your shock rebuild bag in the kit.
Old 05-22-2011 | 09:31 PM
  #1915
BLbound's Avatar
Nice sway bars! Hopefully the AE ones will be out before the end of this month! I sure could have used them yesterday at west coast!
BLbound is offline
Old 05-22-2011 | 09:34 PM
  #1916
sand viper's Avatar
Hey guys, just wondering what you guys are running for rebound also, whats working best for all you? im currently running non, gonna change it up a bit though
sand viper is offline
  #1917
Ok, help guys, someone go grab your cvd shaft with a pair of pliers, and see if the cup moves around a bit, mine does, it's the same both front and rear, about 2-3 mm at the end of the cup in all directions????
Dragrcr is offline
Old 05-22-2011 | 09:35 PM
  #1918
ktm11rider's Avatar
ok thx guys i will give it another shot
Old 05-22-2011 | 09:47 PM
  #1919
Default missed that
re west coast (my local track) how did the top 4 run 20 laps in the sat. points race? i could not be there...
Old 05-22-2011 | 09:52 PM
  #1920
Default almost none
Just did that and there is little to no movement on any of my cvd cup. the whole thing moves the amount between the barring and the pin
