Like Tree5Likes
SC10 4x4 Thread
Old 05-20-2011 | 12:53 PM
  #1696
Originally Posted by Chuck 21
Thank you Chris, now could you tell us if the body is on
or off for the team set up's on your web site..
Thank you and good luck at the warm ups'
Body off.
Chris Jarosz is offline
Old 05-20-2011 | 01:04 PM
  #1697
Wow, I've totally missed this thread. Got some reading to do..!
Here's my car though
Limpan is offline
Old 05-20-2011 | 01:06 PM
  #1698
turbowop's Avatar
Originally Posted by JEFFs SC10
You mentioned you put on Losi shocks that are softer which will increase body lean. Are you planning on putting stiffer springs and oil. What is the upside to putting Losi shocks on?
Stock shock springs are:
* Stock Front – Blue (Short), 4.3LB
* Stock Rear – Blue (Long), 2.8LB
Losi reds:
Front - 4.1lb
Rear - 2.5lb
Not a huge difference. My local track is super bumpy loam natural dirt. The softer the suspension, the better. Once I finally get this thing on the track, I'll test out both sets of shocks to see what I like best. I just wanted to add this to the thread as a data point that other shock options are available.
turbowop is offline
Old 05-20-2011 | 01:10 PM
  #1699
Originally Posted by Chris Jarosz
Body off.
Thank you for taking the time top answer Chris"
Now if this info. gets on the front page for everyone we're dailed"
Once again, Good Luck over there"
Chuck 21 is offline
Old 05-20-2011 | 01:12 PM
  #1700
DRRC's Avatar
Sorry you haven't gotten any info. I am in Finland right now for the IFMAR World's Warmup so I haven't been following this thread at all.
But Chad Due is correct, you measure from between the center/front chassis and center/rear chassis.
Thanks for all your suggestions Chris, Rick and Chad
I do appreciate your efforts in posting and helping us get the right set ups for the sc10 4wd. Can you imagine playing golf and getting tips from Rocco or Adam Scott. Well these racers are of these golfers caliber and they still find time to help us out. What is sad is we still have people complaining about not having enough info.
thanks again guys
For the shocks
I dont see any problems with the bladders on except that they dont compress as much as the emulsion type shock. I had to remove the screw and compress them multiple times and put the screw back. Now they work better and compresses more compared to before. It feels smoother now. Maybe they just put too much shock oil havent rebuilt mine yet.
And I think adding a sway bar will be very beneficial for the shocks and the car to run smoother and less twitchy.
My 2 cents
DRRC is offline
Old 05-20-2011 | 01:13 PM
  #1701
Bringing the new sc10 4wd up for racing tonight Chuck?
Culetto is offline
Old 05-20-2011 | 01:27 PM
  #1702
1fastslash's Avatar
heres mine i hope im doing this right lol
1fastslash is offline
Old 05-20-2011 | 02:54 PM
  #1703
Default Novak 4.5 with 12t pinion - thoughts on this set up?
Are folks stepping up to 13t or higher on this motor?
It came off pretty hot - going on faith that it's not a binding issue but may be geared wrong.
Thanks,
Yapster
yappster is offline
Old 05-20-2011 | 03:13 PM
  #1704
Jim Hustins's Avatar
Thanks,
Yapster
What is pretty hot? Do you have a temp gun? What size track are you running on?
I noticed on a small clay track using the 13t mine hit 130 after running for close to 5 minutes. On a large outside track also with the 13t, after 10 minutes it was still only around 115.
The next time I go back to the small indoor track, I will go with the 12t. Or I might put my 5.5 or 6.5 in.
Jim Hustins is offline
Old 05-20-2011 | 03:30 PM
  #1705
Default re. hot motor: track is fairly large
and pretty loose. Long straight away, long sweepting ends and typical infield. Picked up a tem gauge on way home - no idea just felt hotter than I've ever noticed other motors. ESC was hardly warm.
yappster is offline
Old 05-20-2011 | 03:49 PM
  #1706
Nope, can't make it to 702 tonight... I'm going to Kingman tomorrow all of
the Havasu guys are going. They closed our Havasu track for tomorrow so
everyone could go to Kingman to race. Some of the Vegas guys are going
to Kingman to race tomorrow. So if you can swing it you might wanna
come down and join us all in Kingman...
Chuck 21 is offline
Old 05-20-2011 | 04:28 PM
  #1707
racene1's Avatar
Originally Posted by HOTH
Was missing the inside belt cover that the front tensioner mounts too. Called last wed/Thursday and they said they would send it right out. Still nothing... i would have thought they would over night it too me or at least 2 day snail mail it
So now I'm gonna miss out on the second night of racing since I got the truck. Tried calling ae tonight but they were closed so I'm ranting on here.
This is what was in the box. Two outside covers instead of one of each
same with me but it was with the springs 3 long and 1 short.
JT
racene1 is offline
Old 05-20-2011 | 04:37 PM
  #1708
VegasHB's Avatar
WTF am I doing wrong?
Got a Castle 1410 geared 12/62 w/32p and it feels underpowered and it's coming off hot as hell. I hit 190 with a 13t and hitting 145 with a 12t. Burned through a standard slipper pad and went to a high torque pad and I still feel like I have to run the slipper pretty tight.
Guys are clearing sections with ease while I feel like I need a bigger run and struggle to make it. I thought the 1410 4 pole was the cats meow but it feels small and runs hotter than most guys are seeing.
Just rebuilt my trannies, they're super smooth and it rolls well when it's not meshed with the motor.
Track is indoor clay, most guys run 21 second laps. It's a tighter track but a lot of the turns are banked sweepers.
VegasHB is offline
Old 05-20-2011 | 04:40 PM
  #1709
racene1's Avatar
wish i could be there tonight also. Work work work
JT
racene1 is offline
Old 05-20-2011 | 04:54 PM
  #1710
Thanks,
Yapster
If you are worried about temps, the 1/10 castle fan can be made to fit that motor. Just have to take the tabs off the top side of the fan where the solder tabs are and it will snap down into place
Keep'N It Cool is offline
