Like Tree5Likes
SC10 4x4 Thread
Old 05-19-2011 | 10:04 AM
  #1561
Wild Cherry's Avatar
Rs should work , but recommend a fan to cool ESC
Wild Cherry is offline
Old 05-19-2011 | 10:22 AM
  #1562
bigs's Avatar
Originally Posted by T-BirdJunkie
Because neither the RS or RS Pro was designed to run in something as heavy as a 4w SCT, dude.
I am runing a tekin rs pro with a tekin 4.5 32p/ 62,12 works well with great power. Temps on the ecs 140 to 150 after a 10 min main. on a med sized indoor clay track.
bigs is offline
Old 05-19-2011 | 10:24 AM
  #1563
ilanstylz's Avatar
Just curious if the castle 2400kv 1415 motor will work with the castle sct esc (not mamba max one) on either the 2wd or 4wd sc10 if geared properly?
ilanstylz is offline
Old 05-19-2011 | 10:30 AM
  #1564
T-BirdJunkie's Avatar
ThunderbirdJunkie retracts all previous statements.
(name that flick)
T-BirdJunkie is offline
Old 05-19-2011 | 10:33 AM
  #1565
Buggy Brad's Avatar
I ran the RS in my slash for 1/2 a year with a 4.5 550. It worked great however heat was a problem, with a fan max temps would be in the 110-120 range after a 12 minute heat. If the fan failed which it did from time to time temps would shoot up to 170-190 range, when I replaced the speed control I cleaned the RS and found the FET's had melted the inside bottom of the case........BB
Buggy Brad is offline
Old 05-19-2011 | 10:37 AM
  #1566
Racecrafter's Avatar
Originally Posted by MarqueeRc
The rctech site went down on me about 10 mins ago...A warning pop up said the site could not open...I checked other sites and they were working fine eliminating my connection as the culprit...I just had finished up a nice sized post that inluded my experiences and inquiries of the day....Thing is, i'm tired from the long yet satisfying and rewarding day..I Will muster up the strength to repost at another time...As I am gonna hit the sack..Instead of counting sheep I may be counting Sc10 4wd's...What a day!As a dorky burnout one said in a classic pinoneering for it's time comedy;
"Check ya laterzzzz"
Always write your "articles" in MS Word then copy and paste.
Racecrafter is offline
Old 05-19-2011 | 10:38 AM
  #1567
Originally Posted by Toiffel
So is everyone getting rid of the shock boots??
YES!
Old 05-19-2011 | 10:43 AM
  #1568
Three of us here at Track Star ran Tekin RS Pro's all last year in our Jammin trucks with 550 and 540 motors.
The 4.5 & 5.5 550's would run about 130 with the ESC at 140-150.
The 7.5 & 8.5 540's would run about 160-180 with the ESC at 120.
The same is true now with the SC10 4X4.
Old 05-19-2011 | 11:16 AM
  #1569
Originally Posted by AnonymousUser
If you followed the instructions and mounted the camber links on the inside hole you will have a ton of negative camber causing your binding issue. They need to be mounted on the outer hole.
I have the shocks mounted on the middle hole of the shock towers and the inside a-arms from the instructions. Did you use the outside holes in the a-arms or the shock tower or both? thanks for the info. (and I have the boots on)
BlackIPs is offline
Old 05-19-2011 | 11:17 AM
  #1570
Originally Posted by 1Fastpede
Heres my version of the Box Art. painted by my buddy slowslug
I love the idea. Nice job.
ben
armourbl is offline
Old 05-19-2011 | 11:29 AM
  #1571
Toiffel's Avatar
What are you guys doing to make the Ballistic's fit?? Any pics??
Toiffel is offline
Old 05-19-2011 | 11:36 AM
  #1572
racer1812's Avatar
Super Moderator
Nothing, well not nothing. Leave the chassis screw that holds the rear plate by the end of the motor out so you can flex the plate out of the way as you "snap" the motor in. The chassis is really close to the end of the motor, probly touches it, but I didn't grind anything to make mine fit. Geared 13/62.
racer1812 is offline
Old 05-19-2011 | 11:44 AM
  #1573
symmetricon's Avatar
Not the shocks, the camber linkage, where the ballstud mounts to the shocktower, should be on the outerhole, not the inner hole.
symmetricon is offline
Old 05-19-2011 | 11:50 AM
  #1574
Shark413's Avatar
I couldn't wait for the Associated sway bars so I added my own. Jammin CRT.5 hardware and homemade bars using K&S music wire. I made them in 1mm, 1.5mm and 2mm sizes. This should help handling on relatively flat high grip tracks and in high speed turns.
Front and rear sets.
Front
Rear
Linkage detail.
Shark413 is offline
Old 05-19-2011 | 12:01 PM
  #1575
McKleroy's Avatar
Anyone else notice that instead of moving the ballstud, swap the tie rod and the camber link? When I built it by the book, I had alot of camber and the toe was way off. Checked the book several times and was built right, and then decided to swap the two. Fixed both issues. Maybe a a misprint?
McKleroy is offline
