SC10 4x4 Thread
#1411
I was told to post this here...
It seems that no one else is having an issue with the front shock tower and the front diff locking when you screw it down. I was told to check the bearings in the diff to make sure that they were pushed in all the way, they are. I was also told to check the lengths of the screws to make sure they werent going into the gear cases, they are the correct length. What am I doing wrong here??
#1414
Unfortunately, you don't have any room to adjust for different pinion sizes. Hope the one you fit on there works well for that motor. It looks pretty small. I would think you'd want something BIG to get anything out of that motor, IMO.
#1415
Could always go to the smallest spur then be able to go up in pinion
#1417
#1418
#1423
I did pull the shocks off and bump the oil up to 40wt front and 35 rear. I have had really good luck with that combo in other veh for my track.
#1424
#1425
From: Norwood, OH...and CCRCR and The OhioRCFactory
Pity ThunderbirdJunkie. He commands it!
5Likes
