T/E Maxx Thread
#481
wow, i see what you mean. thats weird. are the turnbuckles on right, or broke? can you push down slowly on the truck and see where or what is causing the wheels to do that?
#482
Look like the tie rods. It looks like it is cause they are not on top. They are behind the wheel that they pull the backs together and that forces the fronts out. How do I correct this?
Actually how is your maxx set up to this?
#483
mine are the same way. i got rpm arms and bearing carriers up front, but stock in the rear. my tie rods are behind the wheels also. when i compress my suspension the wheels just go in at the top. but they dont move outwards like yours. could you make a video maybe of you compressing the suspension and watching the wheels?
#486
#487
ok, 2 of the pics are the front with my rpm arms and knuckles. and the other 2 are of the rear stock arms and knuckles. sorry kinda dirty,lol. i noticed you got the older knuckles. but still, your wheels shouldnt do that.
#490
#491
right on a thread i can get into. i have 2 tmaxxes one was originally a pro .15 that i converted to a 2.5r RRP steel spur gear hi tech steering servo wheelie bar and a few bodies the other is a stock pro .15
#493
Ooooooooo ok put on the under side! I got it now. I was thinking there was another place on the frame to put the tie rod on. Ok I can try that then I will post again.
#494
let us know if it helps.
