T/E Maxx Thread >
T/E Maxx Thread
T/E Maxx Thread
Old 05-17-2011 | 11:12 AM
  #481
ckblood05's Avatar
Originally Posted by FLATLINE XTR
Here are a couple pics. The wheels are perfectly straight when sitting normal. Sorry they are fuzzy my phone sucks.
wow, i see what you mean. thats weird. are the turnbuckles on right, or broke? can you push down slowly on the truck and see where or what is causing the wheels to do that?
ckblood05 is offline
Old 05-17-2011 | 11:53 AM
  #482
FLATLINE XTR's Avatar
Look like the tie rods. It looks like it is cause they are not on top. They are behind the wheel that they pull the backs together and that forces the fronts out. How do I correct this?
Actually how is your maxx set up to this?
Attached Thumbnails T/E Maxx Thread-2011-05-17_14-43-18_880.jpg   T/E Maxx Thread-2011-05-17_14-43-38_853.jpg   T/E Maxx Thread-2011-05-17_14-43-46_702.jpg
FLATLINE XTR is offline
Old 05-17-2011 | 12:42 PM
  #483
ckblood05's Avatar
mine are the same way. i got rpm arms and bearing carriers up front, but stock in the rear. my tie rods are behind the wheels also. when i compress my suspension the wheels just go in at the top. but they dont move outwards like yours. could you make a video maybe of you compressing the suspension and watching the wheels?
Old 05-17-2011 | 12:47 PM
  #484
ckblood05's Avatar
i wonder if your tie rods are to short or need adjusted? its like when you compress your suspension the tie rods are pulling the wheels in at the rear of them.
Old 05-18-2011 | 07:53 AM
  #485
That is what's happening. Can you take a pic of yours of both points that the tie rod attaches to. That way I can see what yours looks like exactly. Thanks.
Old 05-18-2011 | 09:10 AM
  #486
ckblood05's Avatar
sure. give me a few minutes.
Old 05-18-2011 | 09:20 AM
  #487
ckblood05's Avatar
ok, 2 of the pics are the front with my rpm arms and knuckles. and the other 2 are of the rear stock arms and knuckles. sorry kinda dirty,lol. i noticed you got the older knuckles. but still, your wheels shouldnt do that.
Attached Thumbnails T/E Maxx Thread-picture-315.jpg   T/E Maxx Thread-picture-316.jpg   T/E Maxx Thread-picture-317.jpg   T/E Maxx Thread-picture-318.jpg
Old 05-18-2011 | 03:52 PM
  #488
What you are experiencing is called bump steer. Try mounting the turnbuckle to bottom of the carrier instead of the top.
gatorssc is offline
Old 05-19-2011 | 09:06 AM
  #489
Wont doing that make it worse?
Old 05-19-2011 | 09:46 AM
  #490
ckblood05's Avatar
i was actually gong to say try that also. you can try it and see if it helps. just put the tie rod end on the lower part of the knuckle.
Old 05-19-2011 | 11:43 AM
  #491
right on a thread i can get into. i have 2 tmaxxes one was originally a pro .15 that i converted to a 2.5r RRP steel spur gear hi tech steering servo wheelie bar and a few bodies the other is a stock pro .15
bonvo is offline
Old 05-19-2011 | 02:54 PM
  #492
I seam to remember reading a thread somewhere that said the turnbuckles should be parallel with the arms, its worth a try.
gatorssc is offline
Old 05-20-2011 | 10:19 AM
  #493
Ooooooooo ok put on the under side! I got it now. I was thinking there was another place on the frame to put the tie rod on. Ok I can try that then I will post again.
Old 05-20-2011 | 10:22 AM
  #494
ckblood05's Avatar
lol, yeaaaaa. let us know if it helps.
Old 05-20-2011 | 05:15 PM
  #495
so whats everyones favorite upgrades for the t maxx? mine is replace the steering servo with something like a hi tech the stock one is a joke
bonvo is offline
