T/E Maxx Thread
#511
ive been searching, with no luck...i asked this question in the rx8 thread, but i figured id ask it here to. im extremely new to the hobby, and am getting ready to install a tekin rx8 combo system in my 3906, but i have no idea how to wire it up for 2 batteries. do i just wire like the directions say, and then add a y-connector? series or parellel? i know my way around a soldering iron and stuff, just un familiar with brushless systems....i already have my mounting stuff for the motor and all that, its just the wiring i could use some guidance on, or even just a link or diagram would be fine
sorry for the newb question, but i'll have photos to post of my first makeover(not enough done for me to call it a 'build', lol) once some parts(mounting plate, hex adapters, bell crank posts) come back from the anodizers.
thanks guys
thanks guys
#512
Got a free T-max how do you tell if you have the new or old version shocks are blue also has a picco max motor. Thing need some work whats recommended not into anything bling its going to be BASHED.
It had Picco Max
MIP CV
Servos will be tossed should I convert whats needed. Please keep in mind this will be taking some abuse.
It had Picco Max
MIP CV
#513
It had Picco Max
MIP CV
It had Picco Max
MIP CV
#516
My question is what model 2.5 or 3.3 old or new ?? Not looking 4 blink just hard bashing want it strong but light ALU isn't my thoughts not extra money for those things it was for free
#517
Thats an older one you got there. Most likely a pro.15 model (the original) with an Ofna/Picco big block kit on it (just a motor mount) or an early 2.5.
It sure looks like the old size chassis, but it might be the first version of the 2.5 truck (I know the hole for the pipe makes the difference). It looks to have the wider 2.5 suspension arms, and the 2.5 shock towers with the multiple shock mounting points.
Straight bashing? I'd go
alumimum
chassis braces
skids
bulkheads
shock caps
rpm parts
everything else you can get
alumimum
chassis braces
skids
bulkheads
shock caps
rpm parts
#518
rpm aren't bling. there very strong parts. the aluminum bulks is because the plastic ones break. and the chasis braces are optional really. it seems he agrees with me to ^^^^^
#519
alumimum
chassis braces
skids
bulkheads
shock caps
rpm parts
alumimum
chassis braces
skids
bulkheads
shock caps
rpm parts
Does Traxxaaa have any good replacement servos the blue ones. What do you recommend just want something i can bash with have the 100 buck stuff don't want to waste.
Also will all the 3.3 RPM arms, and items listed fit or do I need to make sure its for the older model as stated.
#520
Thanks for the info the throttle linkage needs a complete replacement can I buy the new setup off the 3.3 version? also there's 3 servos one for steering one for throttle/ brake the other is going into the center diff? Whats the for 2nd gear? Is there a conversion
#521
these would work-
http://cgi.ebay.com/RPM-T-Maxx-2-5-2...item2c5d41b26e
http://cgi.ebay.com/RPM-T-Maxx-E-Max...item2eb59293ae
http://cgi.ebay.com/RPM-Traxxas-T-Ma...item51999beb57
http://cgi.ebay.com/RPM-80135-FRONT-...item43a4b7387f
http://cgi.ebay.com/RPM-80105-BLUE-F...item3f09a0ca9b
http://cgi.ebay.com/RPM-80155-F-R-BL...item43a5ec463e
http://cgi.ebay.com/T-Maxx-Blue-Shoc...item5644aeb3a3
http://cgi.ebay.com/RPM-80035-Blue-A...item1e58d86599
http://cgi.ebay.com/TRAXXAS-TMAXX-EM...item3f0b6cc754
http://cgi.ebay.com/Traxxas-4923X-Ch...item4cf824f023
http://cgi.ebay.com/Traxxas-3767A-Al...item5199cf017e
#523
#525
I just received my first emaxx #3906 four days ago and I love it. I have a nitro pede .15 that i just got a month ago. I love the maxx the most though. Now I wanna upgrade it so that way I can really tear the neighborhood up. Looking to get the kersawn dual 700ho. Just need to figure out which way to go for batteries. I am thinking Lipo with an evx-2 swap.
