Like Tree5Likes
SC10 4x4 Thread
Old 05-11-2011 | 12:44 PM
  #451
Jstall7543's Avatar
Originally Posted by DRFTPRO
Tension seems good but I will check it. Do you recommend the 13t pinion cuz I was under the impression that going up in the teeth would keep the engine cooler. Thanks a bunch bro!
The tekin 4.5 is a motor, not a engine.
Jstall7543 is offline
Old 05-11-2011 | 12:45 PM
  #452
Originally Posted by Chuck 21
I'm looking forward to driving my SC10 4x4 because I liked the original
4x4 25 years ago that had the same design (MIP RC10 4x4 conversion)
How is it the same design? Just because it uses a belt doesn't mean it's the same. The MIP conversion doesn't even have a front gearbox.
CraigV is offline
Old 05-11-2011 | 12:46 PM
  #453
Revoke36's Avatar
Originally Posted by BC slasher
im with you on some feed back .ive asked twice .i can only ASSUME the truck is not all that.i personally feel the truck is a bit to light.if this truck was planted and dialed ,racers would be posting it.im a bit dissapointed,ive been waiting a long time for this truck and im not sure i shld get one now.
Follow this guy http://www.youtube.com/watch?v=OwpKaJmf4IE
He'll do a down-to-earth-review on it soon.
Revoke36 is offline
Old 05-11-2011 | 12:48 PM
  #454
ilanstylz's Avatar
Originally Posted by oitz
If you remove the 18mm screw and nut that holds the back to the middle body component and bend them apart, you can slide the motor in (with a little work).
Sweet thanks, I'll try both motors out the 2400kv 1415 and the 3800kv 1410 and see which I like better..........
ilanstylz is offline
Old 05-11-2011 | 12:58 PM
  #455
Jstall7543's Avatar
Originally Posted by Keep'N It Cool
I still haven't quite grasped this concept of going up in teeth cools the engine. Essentially what you are doing when you go up in teeth is putting more load on the motor because you are trying to spin the wheels faster. More load means more current which means more heat. If someone says youa re running to many RPM's and that is causing you to overheat, that is not right. If you have heat issues you should lower the pinion size not increase it.
If esc is at 100 and the motor is at 170 then go up a couple teeth. Then the temps would be more like 125esc/140motor. Also make sure your battery has a high enough c rating to do the job. I noticed your in Texas so I assume temps are mostly on the high side, so what works in WA may be a mistake in Texas.
Old 05-11-2011 | 12:59 PM
  #456
turbowop's Avatar
+1
They are both belt driven, nothing else is different. Suspension geometry is different, motor mount is in a different location which changes the weight balance along with mounting of all other components. People need to stop comparing the old MIP conversion to this thing. They're worlds apart.
turbowop is offline
Old 05-11-2011 | 01:07 PM
  #457
rctouringracer's Avatar
Originally Posted by davidfast
I still see them there
Thx for the double check! Computer glitch on my end...
rctouringracer is offline
Old 05-11-2011 | 01:09 PM
  #458
Jstall7543's Avatar
I'm feeling the same way you are, I have 5 other AE rc's but have to admit after seeing a dialed losi... I almost bought the sc10 4x4 lastnight but couldn't push the button. The losi I saw was bone stock roller with bar codes and ballistic 4.5 and it was putting down some of the fastest laps I've seen at my local track. So sick!
I need to see this truck winning some races and not rolling over all the time, why didn't they include sway bars, kinda dumb if you ask me for a truck the pro's can't seem to keep of four wheels. I still haven't lost faith but I need some more convincing before I buy one.
Old 05-11-2011 | 01:16 PM
  #459
BmainStar's Avatar
LOL Must be an Engineer!
BmainStar is offline
  #460
GMartinez's Avatar
Fyi 1st batch sold out in minutes we just recieved the 2nd order total of 4 kits now instock website is not updated yet
http://www.superiorhobbies.com/istar...id=ASC90004!SH
GMartinez is offline
  #461
can anyone please post their camber link measurements?
SDfitted is offline
Old 05-11-2011 | 01:17 PM
  #462
BmainStar's Avatar
Maybe loose nut behind the control? LOL
Old 05-11-2011 | 01:19 PM
  #463
Originally Posted by turbowop
+1
Some people don't see the similarity between a diesel submarine & a nuclear
submarine. Thats just the way life is. No worries guys, it's all good...
Chuck 21 is offline
  #464
Jstall7543's Avatar
Why not get someone else to film the truck so he could drive it better, to me this video makes the truck not look that good.
  #465
1Fastpede's Avatar
is there an ideal tool to remove shock pins?
1Fastpede is offline
