Team Associated RC8Be Thread
#5911
Tony's screw kit
Mugen Diff Gaskets
1404 FT Blue Titanium Turnbuckles, 1.775"/45mm
Avid Revolution Bearings, all sizes, two or three of each
89350 Rear Spring Set, complete
89295 Front Spring Set, complete
89229 FT Blue Countersunk Washer
89025 upper and lower arms
89032 caster angle bushings
89030 caster block
89030 hinge pin bushings
89074 steering rod ends
89076 camber rod ends
89077 chassis brace rod ends
89090 Antiroll Bar Ball Joint
89091 FT Antiroll Bar Socket Joint
89519 Plastic Spur Gear, 46T
89521 Plastic Spur Gear, 50T
89114 Diff Pinion Gear
89117 Diff Shims
89469 HD shock ends
89083 Shock bushings
89470 tower pin bushings
89017 gear box
89121 diff o-rings
#5912
Anyone interested, I've got a Tekin RX8 and Tekin 1700 motor for sale.
http://www.rctech.net/forum/r-c-item...0kv-motor.html
#5913
What connectors is everyone using?
I use deans but they are not holding up. Not handling the current. I use 4C Lipos.
If you are using deans how old are they? The one on the ESC is the one not lasting for me.
#5914
Ive had great luck with Traxxas connectors.. been using them for about 2 years with no problems what so ever.
#5915
My kid's slash has the Traxxas ones - pretty nice too. But for soldering the EC5's are easier, IMHO. I prefer soldering into a cup vs. flat spades.
j
#5916
I've been using Deans connectors ever since I converted my buggy (last August) and never once had a problem with them. What gauge wire are you using?
#5918
6mm bullet connectors for me. Been through Traxxas and Deans and was not happy with them. If I could go back in time I would go with the EC5 connectors. Same as the bullets but protected with the plastic casing.
#5921
