Team Associated RC8Be Thread >
Old 04-21-2011 | 05:47 PM
  #5761
arvint's Avatar
Pics as promised!
Never liked painting black bodies..but I had 4 bottles of black leftovers..so I got lazy..but it came out nice
Wish the motor could go lower
Can't find out why I can use the grid motor mount without putting the motor riser...Body rubs against the motor wires due to the motor bieng high.. :/
arvint is offline
Old 04-21-2011 | 05:51 PM
  #5762
DRUNKENMASTER's Avatar
Thumbs up
I like the blacked out look you have there! Nice!
DRUNKENMASTER is offline
Old 04-21-2011 | 06:07 PM
  #5763
For those who've driven this vs the Eco, what's your input on it?
BoneDoc is offline
Old 04-21-2011 | 06:21 PM
  #5764
Originally Posted by customss
yes, run timing advance at 100, this way if your sensor wire goes it will run in sensorless mode, wont have the same punch, but it will still run
No, no, no!
You do not want to run 30 degrees of timing.
Leave it at minimum
Also, drop your neutral width to 5 or 10 depending on what radio have.
bohdi is offline
Old 04-21-2011 | 06:23 PM
  #5765
per4m28's Avatar
Ive gotten the chance to drive the eco a few weeks ago and IMO it was very impressive, much more stable and not as twitchy, this would depend on setup also, but the one I drove was right out of the box with stock settings. Would like to test ride the
XB808
per4m28 is offline
Old 04-21-2011 | 06:25 PM
  #5766
love the black with black rims!
customss is offline
Old 04-21-2011 | 06:31 PM
  #5767
per4m28's Avatar
yes yes yes, not boost, but timing advance, it only kicks in if the motor doesnt reconize the sensor, straight from tekin themselves
lol...your right about the 100 timing setting, not sure what he meant to set nuetral width to 5 or 10 he might of meant never to go below 5 as factory setting is 56 or so.
per4m28 is offline
Old 04-21-2011 | 06:56 PM
  #5768
arvint's Avatar
Originally Posted by bohdi
No, no, no!
Leave it at minimum
Wait..so I should put timing advance to: Min.
Just want to make sure
arvint is offline
Old 04-21-2011 | 07:09 PM
  #5769
I like the black body also makes me want to do 1 like a skunk with a white stripe
monsterbrad is offline
Old 04-22-2011 | 12:21 AM
  #5770
buggy8's Avatar
one roller ready to race! phew
I took every screw out
-Installed a new GRID mount, never to be used by me
-New machined aluminum front hubs
-replaced with new, or cleaned every bearing
-25/25 newly rebuilt shocks (which didn't need it, they were spotless inside)
-All new shock boots
-5,5,5 diffs, sanded and super clean with Mugen gaskets and new gaskets
-replaced a bunch of rough bushings
-scrubbed every spec I could off of it
smoother than it's ever been and I'm not even going to run it
I enjoyed every second of the process
now onto number two...
buggy8 is offline
Old 04-22-2011 | 05:27 AM
  #5771
Please read the tekin forum. The t8 motors do not work like a 540 size motor with timing. Your added timing will just create heat issues. I have NEVER seen a tekin setup for off road 8 scale with that much timing used.
Why would you set up you equipment in case of failure of the sensor
Do not listen to me and especially do not listen to these other people. Just get on the tekin forum and ask. Check out all the setups on teamtekin.com. 
bohdi is offline
Old 04-22-2011 | 06:44 AM
  #5772
schnellschnell's Avatar
Pics as promised!
How did you get that steering rack to fit - I couldn't get my turnbuckles short enough to accomodate it. Do you have a part number for turnbuckles that fit?
BTW, a black car is what Mad Max drove. Nice.
j
schnellschnell is offline
Old 04-22-2011 | 08:01 AM
  #5773
PTP Racing's Avatar
I was wondering about the steering rack too. Why? The kit one was an upgrade from that older version although I didnt notice much of a change when I made the switch.
PTP Racing is offline
Old 04-22-2011 | 08:03 AM
  #5774
PTP Racing's Avatar
I saw in the picture where it looks like you modded it. Did you do it just for weight savings?
Old 04-22-2011 | 08:08 AM
  #5775
PTP Racing's Avatar
Oh and your solid black looks 100x better then the hack job I did to my kit body. I dont think I will ever try and paint anything ever again. I think I must have gotten some silicone spray on it or something because the paint was fish eyeing, running, and bubbling. I cleaned it all off sanded the body and tried again and had the same problems. Its a shame because I really like the body too.
Anyone try a Bitty Designs body? My painter got one by mistake and asked if I wanted it painted up so I said yes but now I am wondering if its going to fit. I have an old Proline Crowd Pleaser that looks very similar and it hits the battery and doesnt sit on there quite right.
