RC10B4.1 FT/WC
Old 04-29-2011 | 11:19 PM
  #2686
jcr
Was looking at the Avid bearing website, what size are the bearings for the steering rack?
jcr is offline
Old 04-30-2011 | 04:38 AM
  #2687
Never ran mod before... what gear ratio to start with for a 8.5 and sxx v2. Would you use timing with it? First try I did 19/87 no timing in motor or speedometers but was same speed as my Gemini 13.5 lol
gguertin145 is offline
Old 04-30-2011 | 04:55 AM
  #2688
try http://www.comeseethis.com/gearing/Default.aspx
tony6187 is offline
Old 04-30-2011 | 04:56 AM
  #2689
mellow's Avatar
Im running an sxx v2 and an 8.5 Epic D3 with 22/81 gearing. hasn't been above 115, and my boost profile is on the default - 3.
mellow is offline
Old 04-30-2011 | 09:28 AM
  #2690
mdwaeracer's Avatar
Tried the lt yellow rear kyosho and dark yellow fronts, liked the way it jumps. Lost steering though. Any suggestions?
mdwaeracer is offline
Old 04-30-2011 | 12:52 PM
  #2691
Timing 3 or feel 3?
Old 04-30-2011 | 05:31 PM
  #2692
mellow's Avatar
Timing 3 or feel 3?
Timing, my throttle feel is on 2 for now
mellow is offline
Old 04-30-2011 | 07:33 PM
  #2693
Derry's Avatar
Try the Kyosho orange fronts...You will get your steering back.
Derry is offline
Old 04-30-2011 | 08:26 PM
  #2694
mdwaeracer's Avatar
didnt pay attention that the kyosho springs were longer. Uh set ride height and hello, steering was butter and have to say it jumps nice with those springs.
Old 05-01-2011 | 02:13 AM
  #2695
TheModTurtle's Avatar
Does anyone here know the weight differences between the aluminum rear chassis plate and the plastic one? Or the weight difference between the steering parts (the steering rack, caster block, and steering block w/axle)?
TheModTurtle is offline
Old 05-01-2011 | 08:46 PM
  #2696
Have you seen any pros running any of the aluminum parts you mention?
PFKAOG is offline
Old 05-01-2011 | 09:06 PM
  #2697
Oh shoot, I didn't realize I asked about performance!! Oh wait... I Didn't...
Anyone (who read the question) know the difference in weight?
Old 05-01-2011 | 10:11 PM
  #2698
burris7555's Avatar
I can check the steering rack for you. I'll PM it to you tomorrow...
burris7555 is offline
Old 05-01-2011 | 10:21 PM
  #2699
Thanks a ton!! When I check out the rear chassis plate on amazon it says the weight for both the plastic one and all the aluminum one's is the same so I know something is wrong there :/
Old 05-01-2011 | 10:38 PM
  #2700
mdwaeracer's Avatar
whats your thoughts on the proline closed cell tire foams for the rear tires?
