NOVAROSSI Engine thread....
#961
#964
#965
ran mmy tor nero team today first time in buggy awesome what a beast but had several ghost flameouts small restrictor alpha 0801 pipe odonnel speed blend and 97 t plug preheated warmed up for 4-5 minutes then during race it flamed about 4 laps in and in the main same thing any suggestions?about 3/4 gallon thru it
#966
probably out of whack on the carb
drop shimming down to .70mm and i would suggest a 9901ss/41021 for buggy
#970
I ran my toro nero for about 3 tanks last weekend. It still has a slight metal pinch so I know it doesn't perform optimal yet; but man it screams!
I run a 13t clutchbell, 9901 with long header and a 6.5mm venturi. It even still ran a bit fat on top. I know I'm gonna like this engine
#972
Hope this helps
#975
Houston
I have novarossi plus 4.
with 4 gallons on it.
I have a problem, I cannot get the engine to idle consistently, sometimes the idle is perfect and sometimes it's rich.
what could be the problem ?
should i change to new bearings ?
or change new carburator
thks
thks
352Likes
It's had around a gallon at the moment so I might lean towards a decent tune.
