Team Associated RC8Be Thread >
Old 04-04-2011 | 03:18 PM
  #5311
GreggW's Avatar
Nice shots guys!
GreggW is offline
Old 04-04-2011 | 03:30 PM
  #5312
chris c's Avatar
chris c is offline
Old 04-04-2011 | 03:37 PM
  #5313
rc person 577's Avatar
Hi guys,
I got an RC8Be over the winter. I asked what motor to get with the RX8 over on the RCU forums, and they said that the 1900 was way too much and the 1700 was perfect. So I got the 1700. Now reading this thread, and other spots aroud here, people say the 1900 is the best one to have.
TBH, I have not read all 355 pages so please forgive me, but do you think I made a mistake with the 1700?
After doing the math on a gearing calculator, if I go up to a 16 tooth pinion, it says, the speed will be the same with less of an amp draw then the 1900 with a 15 tooth. Is this an option?
Sorry, don't want to hijack the thread.
Thanks!
rc person 577 is offline
Old 04-04-2011 | 03:42 PM
  #5314
symmetricon's Avatar
Originally Posted by rc person 577
Hi guys,
TBH, I have not read all 365 pages so please forgive me, but do you think I made a mistake with the 1700?
After doing the math on a gearing calculator, if I go up to a 16 tooth pinion, it says, the speed will be the same with leaa of an amp draw then the 1900 with a 15 tooth. Is this an option?
Thanks!
Are you using 4s, or 5s?
symmetricon is offline
Old 04-04-2011 | 03:48 PM
  #5315
Most likely 4s, however, I could run 5s if I have to.
Old 04-04-2011 | 03:53 PM
  #5316
On 4s a 16t pinion will be slow. I run a 1800/5s with a 15t tekno traktion cluch and a 46t spur and the speed is spot on.
Old 04-04-2011 | 03:56 PM
  #5317
rednck21's Avatar
Hi guys,
Thanks!
you didnt make a mistake, but you will need a 22 or 23 tooth pinion with 4s. i run a 1900, but still have my 1700 as a backup if i need to make a longer main
rednck21 is offline
Old 04-04-2011 | 05:01 PM
  #5318
Wow! Thank you all for the quick responses. I will pick up a 22 and 23 tooth pinion. What is the pithch? mod. 1? I have a 16-20 set for my flux that are mod. 1 so it would be nice to have the same set for both cars.
Thanks again
Old 04-04-2011 | 05:02 PM
  #5319
B.A. Racer's Avatar
Thanks again
yes mod 1
B.A. Racer is offline
Old 04-04-2011 | 05:05 PM
  #5320
117's Avatar
117
I run a 22T Mod 1 pinion from Hot Bodies with a 2050kV Tekin T8 motor with no temp issues so far, but we haven't hit the 100F ambient days yet here in Texas.
117 is offline
Old 04-04-2011 | 05:20 PM
  #5321
rednck21's Avatar
make sure its a 5mm bore. I like the HPI pinions because they will work with my awesome Grid mount
rednck21 is offline
Old 04-04-2011 | 05:26 PM
  #5322
PTP Racing's Avatar
Ok so Ive decided to get a Tekin motor speedo...but what KV?
I plan to run 4S lipo but what C rating and how many mah? I found some 25C 5000mah packs cheap online.
PTP Racing is offline
Old 04-04-2011 | 05:34 PM
  #5323
R-E-A-P-E-R-'s Avatar
1900kv
R-E-A-P-E-R- is offline
Old 04-04-2011 | 05:36 PM
  #5324
per4m28's Avatar
min for rx8 30C
per4m28 is offline
Old 04-04-2011 | 05:38 PM
  #5325
rednck21's Avatar
i wouldnt buy anything less than a 30c 5000, but get a 40c if you can afford it. i read somewhere these things can pull 150 amps...
rednck21 is offline
