Team Associated RC8Be Thread >
Old 03-16-2011 | 08:00 PM
  #4426
Originally Posted by 117
Pictures please?
here you go with a better pic
bohdi is offline
Old 03-16-2011 | 08:14 PM
  #4427
schnellschnell's Avatar
That LiPo sack (box?) is very interesting. Who carries it? I'm having a hard time finding someplace that has it.
The bag seems to be from this store in Germany.
http://www.tonisport.de/?___store=en..._store=english
Not on their site yet, the article mentions April. Seems too good to not have other companies use the same format.
You guys use the bags for charging, storage, transportation or all 3? I store and charge in an ammo box. Haven't transported them yet.
j
schnellschnell is offline
Old 03-16-2011 | 08:15 PM
  #4428
WHAT A NIGHT!!!
Gregg, thanks for all of your help with the advice on the chargers and batteries:
Here's order #1 out of tower:
LXZHV5 THS Racing C70 1/8 Car Hard Tire Dish Rim In stock, shipping 1 $23.49
LXSKG7 Associated Wing Mount RC8 In stock, shipping 1 $10.29
LXAXFU Associated Reedy LiPo 14.8V 5500mAh 60C In stock, shipping 1 $164.99
LXAPDR Associated Silicone Shock Fluid 32.5wt 2 oz In stock, shipping 1 $3.39
LXAPDP Associated Silicone Shock Fluid 27.5wt 2 oz In stock, shipping 1 $3.39
LXAVKK JB Weld J-B Perma-Lock 6ml Red Threadlocker In stock, shipping 1 $5.99
LXGDU8 W.S. Deans Female Ultra Plug (2) In stock, shipping 1 $2.69
TOWZ2001 Tower Hobbies AMA Lithium Battery Warning In stock, shipping 1 $0.00
The following items will be placed on back order
These items will ship to you when available
LXATGZ Associated Factory Team Nut Driver 5.5mm Out of stock, back ordering 1 $11.99
DTXC3615 DuraTrax 1/8 Lockup Buggy Tire C2 Mounted White (2) Out of stock, back ordering 1 $24.99
Total Current Charges: $ 214.23
#1 Wow - 5.5mm thin socket out of stock? Yep, RC8be owners are snatching up that one!
#2 The 40.00 coupon will come into play once my tires and socket are in. So this order is really $211.00
Here's my next one: @ Ep buddy for my charger stuff:
1 xJunsi 350W DC Power Supply P350 (P350) $68.00
1 xiCharger 206B battery charger (206B) $139.95
1 x12" 4S JST-XH balance extension cable $2.25
Sub-Total:$210.20
Shipping:$0.00
Total:$210.20
Next, got this:
DE Racing Mud Plates:
Mud Guards, Associated RC8 / RC8E / RC8B / SC8 DER-110-A$6.95
Finally, got a Lipo Bag from Amain because tower had crap:
1 x ProTek R/C Lithium Polymer Flame Resistant Charging Bag (23x30cm) (PTK-LIPOSAFE) = $19.99
I'll be picking up a 50 Cal military issue Ammo can to store my lipo's in and my container to go to and fro the track:
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
I'm BLLs deep into this car man..........
After getting 1 Gens ace for practice, yeah... unless something breaks; I'm over buying stuff. I've got everything I could possibly want for this car.
Uh hum....
Grand total I've put into it....
Estimate +/- $150 margin of error - $1800.00
When I was warned 1/8 scale was expensive, ... I was warned...
And it didn't help I had nothing of the LIPO class. I needed everything from the ground up.
Sarinexia is offline
Old 03-16-2011 | 08:36 PM
  #4429
DRUNKENMASTER's Avatar
I have a couple of lipo bags from hobbypartz that I never use. I don't even see anyone at the track using them.
DRUNKENMASTER is offline
Old 03-16-2011 | 09:01 PM
  #4430
GreggW's Avatar
Yeah, I got a chuckle from Seville Bravo this past weekend about my lipo sack. I'd rather be safe than sorry. I know the likelihood of something happening is slim. But I still don't want to ruin anything but the batteries if they give out.
GreggW is offline
Old 03-16-2011 | 09:18 PM
  #4431
RickyBBad's Avatar
Originally Posted by toobad4u
I ran my RC8B-E for the first time this past weekend, besides a couple runs up and down my road to make sure everything worked. It was @ the PNB. I started out with everyone's favorite, the RX8/1900 combo and a 19 tooth pinion. After 3 laps of practice I was forced to switch over to my backup MMM/2200 combo. The Tekin just could not handle all of my belly slap landings I guess. It was smooth before it quit working. The MMM I have is the older version, V2.99, and the motor has a ton of run time on it. The metal seal on the front bearing was actually loose inside the top of the rotor inside the motor when I took it apart to clock the front part of the case. I cleaned the bearing, lubed it with oil, and put some AE black grease on it for a make shift seal. I re-installed the metal bearing seal (that was broken) and turned the bearing around so the front housing held the seal in. It lasted through practice and all 3 rounds of qualifying. I ended up qualified 9th in the A-main, but had to leave before they got around to the 36th, and the 41st mains. Not bad for the 1st time out I think.
My E-car was hooked up much better than my nitro. I was running the stock setup suspension wise, with 30wt front oil, 25wt rear oil, 10 hole pistons, and blue Jammin springs all the way around. Everything else was per the setup sheet. I was getting 15 minutes during practice on the PNB track with my Turnigy 4500mah 4s packs. They would take 4480 mah back into them after the 3.2v cutoff kicked in. After the 10 minutes quals. they were @ 3.88v per cell and took 3000-3100mah to reach full charge.
I will be trying the new M2C shock pistons soon. I have heard that they actually make a significant difference.
Stephen
Id be happy to take that Tekin off your hands for you. how do $100 sound?
RickyBBad is offline
Old 03-17-2011 | 05:35 AM
  #4432
TCarlson777's Avatar
Default 1700 on 4S or 5S
I have a 1700 Tekin and was curious if anybody is running this on 4S? If so, does it have plenty of top end on the 4S, or would 5S be best?
TCarlson777 is offline
Old 03-17-2011 | 05:40 AM
  #4433
orgnoi1's Avatar
My opinion is PURELY speculatory since I havent even driven my buggy yet... but I would say that on 4s it would be good for short tight tracks... 5s would give you the bit higher overall speeds which you may need on "normal" tracks... and I am sure you could even get up into the 6s range and run a smaller pinion to get the same effect...
orgnoi1 is offline
Old 03-17-2011 | 05:41 AM
  #4434
DavidR's Avatar
1700 is probably going to be a bit lacking on top end for most with a 4S.
I've run a 1700 on 4S quite a bit INDOOR... But outdoor I think you'd be at a bit of a disadvantage.
DavidR is offline
Old 03-17-2011 | 05:44 AM
  #4435
where can you buy the m2c pistons, i havent seen them on their site
agarabaghi is offline
Old 03-17-2011 | 06:07 AM
  #4436
117's Avatar
117
I thought the M2C pistons were pretty much the same as the 10 x 1.1 tapered AE pistons. They're not on M2C's web site anymore, for whatever reason.
117 is offline
Old 03-17-2011 | 06:26 AM
  #4437
jwmustang's Avatar
Default Knurling Double Nut Wrench (5.5, 7.0mm)
Not sure how thin the walls are but looks like it should fit the top of the shocks.
http://www.miracle-mart.com/store/in...oducts_id=4473
jwmustang is offline
Old 03-17-2011 | 06:39 AM
  #4438
GreggW's Avatar
I posted this a few pages back. Mine came with my Hyper 7.
http://www.amazon.com/gp/aw/d/B000BR...SIN=B000BRPE26
GreggW is offline
Old 03-17-2011 | 06:43 AM
  #4439
toobad4u's Avatar
Call them directly. The pistons are different that the AE ones. Some people got them @ the PNB and ran them there and said there was a difference. That track was blown out pretty bad, so it was probably a good test area.
Stephen
toobad4u is offline
Old 03-17-2011 | 07:12 AM
  #4440
Originally Posted by Sarinexia
WHAT A NIGHT!!!
That is what I thought a bit ago. Just ordered another $100 in spare parts, oils, ride height gauge etc.
It never ends!
j
