Team Associated RC8Be Thread >
Old 03-01-2011 | 12:19 AM
  #3721
Doug2507's Avatar
Originally Posted by GreggW
soldering isn't your strong point, is it?
(not thats mine's amazing either!)
Doug2507 is offline
Old 03-01-2011 | 05:16 AM
  #3722
jwmustang's Avatar
Originally Posted by NoLuVv
Thanks, I have not, fully plan too once their tracks are up and running again.
NoLuVv, the Fort Walton one is up and running. We had our first race last weekend. Next one is 3/12.
Info on track is here:
http://b-treman-rc.valp.net/btrchome.htm
If your in the area it is always open for practice and it is free.
There is another one opening in Mossey Head.
jwmustang is offline
Old 03-01-2011 | 05:19 AM
  #3723
117's Avatar
117
Originally Posted by buggy8
12 gauge speaker wire seems the same, I have some rockford fosgate stuff that seems identical to all of the high dolla bill wire.
It most likely is, as all of it is OFC wire with a high strand count. The only thing I don't like about much of the aftermarket speaker wire offerings is that it uses such thick insulation. The Dean's stuff (and there are other brands just as good, like the stock Tekin stuff) is very flexible and the insulation is rather thin. I've been spoiled by Tefzel wire that I use in my race car. Super thin insulation. It makes the wiring very tidy and light. I suppose I've just gotten to the point where I dislike wiring with super thick insulation.
Yea man, I got two new in package at home. If you want one, ill share the wealth. Pm me your address and ill send you one on the free. In a giving mood tonight what can I say.
Can get it out Wednesday.
Good deal. Nice to see offers like this. Have any 1900kV or 1700kV Tekin motors just laying around?
Originally Posted by Handbrake
This is the way i soldered my battery, and motor connectors to my speed controller on my Associated Tc5 and Tc6. I will do the same on my RX8 when it arrives. They are 3.5mm female plugs and i sat the outside ones in the grooves on the posts, and the middle one centered. This gives good clearance between all three posts. The advantage of mounting the wires like this apart from looking neat, is two fold. It makes changing motors a breeze without having to re soldier, and secondly it increases the surface area on the posts for the heat to disapate. To solder, just turn the speed controller upside down heat the connector and let the solder flow into the bottom of the female plug and surround the post and fill the groove.
Please post pictures when you do this. I'd be very interested in seeing them. It would be ideal to have large bullet connectors on the RX8, IMO. Just so I'm understanding you correctly, you're filling the bullet connector with solder, like you normally would when soldering wire to the bullet connector. However instead of inserting wire, you just turn the ESC upside down and insert the wire post. Seems logical, and a very good idea.
The only observation I have is that I wonder if the additional weight of the bullet connector pieces (both on the wire post and on the wire) adds a significant amount of stress onto the wire post where it's mounted on the ESC board. I would assume not, since you (I assume) haven't had any issues with the way you've done this on your RS Pro, but the wire posts on the RX8 are much taller and might have more leverage on the board. Just a thought.
117 is offline
Old 03-01-2011 | 05:21 AM
  #3724
God am i addicted or what. I woke up this morning and figured I could bike from work to the lhs this afternoon to pick up some wire and the castle creation bullets. Got up, plugged in the soldering station and removed the wires. I then took the motor out, put it in my backpack and biked to work....
See i didnt ruin the motor
agarabaghi is offline
Old 03-01-2011 | 05:23 AM
  #3725
Also a TC5 and TC6 don't exactly come slamming down from 5+ ft in the air over and over
  #3726
Leodis's Avatar
*Unsubscribe*
I'm sick of wading through all of the off-topic and misinformed posts to find useful information.
Leodis is offline
Old 03-01-2011 | 05:24 AM
  #3727
117's Avatar
117
BTW, understatement of the week...no month...year maybe?
117 is offline
  #3728
Originally Posted by Leodis
*Unsubscribe*
k bye.
Old 03-01-2011 | 05:25 AM
  #3729
117's Avatar
117
Before you solder up the new wires, remove some of the solder from the pads. It looks like there's way too much.
*Unsubscribe*
How ironic. An off-topic post from someone complaining about off-topic posts! Sorry guys, I'm pretty guilty of this. Is it bothering everyone else? If so, I'll certainly rein it in.
117 is offline
Old 03-01-2011 | 05:26 AM
  #3730
speaker, ace hardware, radio shack or any other similar wire is NOT the same.
That wire is not made to sustain the currents that these electronics deliver.
Get the 12G silicone wire as that is what it is made for.
It is also a good idea to put new wire on after prolonged use.
bohdi is offline
Old 03-01-2011 | 05:36 AM
  #3731
Gonna have to disagree with high end speaker wire not being able to handle these currents.
Old 03-01-2011 | 05:37 AM
  #3732
Yea for sure, i will probably remove most of it and use some better solder with flux in it.
Old 03-01-2011 | 05:44 AM
  #3733
btw... just ordered 2 of these...
http://www.hobbyking.com/hobbyking/s...dProduct=15521
Old 03-01-2011 | 05:50 AM
  #3734
117's Avatar
117
+1. OFC is OFC, and its current handling limits are based on its cross sectional area and length of the conductor. The main differences I see are based on the insulation, strand count (and thus strand gauge) and whether or not the wire is pre-tinned.
Now, if 12 ga speaker wire is smaller than 12 ga RC wire (which it shouldn't be, as the gauge should be standardized across all manufacturers), then I'd agree with idea that 12 gauge speaker wire will not handle as much current.
Another thing to keep in mind is that speaker wire manufacturers might spec a lower current due to the lenth that is being assumed. If you look up some standard wire gauge specs, you'll see that for a 12 gauge wire, max current is usually spec'ed at 40-45A. We run a LOT more than that, but the wire is so short that it doesn't make much of a difference.
IIRC, conventional wisdom is that you want no more than 2% voltage drop over the length of the conductor when calculating max current capacity. For efficient systems, you can try for 0.5% to 1% voltage drop.
Even with 12 gauge wire at 120A for a wire that's only 3" long, with a 4S battery, the voltage drop is only 0.32%. It's even better with 6S at only 0.21%. 10 gauge is better at 0.20% and 0.13%, respectively.
117 is offline
Old 03-01-2011 | 07:00 AM
  #3735
schnellschnell's Avatar
Originally Posted by Sarinexia
Man... this snow has to melt so I can get out there and drive!
I know how you feel. Sitting there waiting all shiny, sucks. My kid's Slash is a blast though - waterproof ESC and servo. I did waterproof my youngest's Losi desert mini so I'm the only one watching.
schnellschnell is offline
