NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE >
Like Tree4Likes
Old 03-01-2011, 03:21 AM
  #3436
Originally Posted by M7H
Define "pro driver"
Not all pro drivers understand everything...
Anyway Cherry did you get my Email
MChandler is offline
Old 03-01-2011, 03:26 AM
  #3437
smilekt's Avatar
Trader Rating: 13 (100%+)
Originally Posted by COBRARACING
Hi Guys
I have just finished the Instructions for the latest release of software just waiting for michael to change the wording in the firmware and we are right .
I have changed the wording so everyone understands from around the globe .
example :Boost timing has changed to the actual real deal (Dynamic timing )meaning the internal timing of the esc .
Turbo timing has changed to (Turbo boost timing ) which is the additional timing added onto the dynamic timing .Boost relates to turbo in the real world .
ok ill post it up tomorrow.
regards Angelo
Thanks Angelo ..
Congrats first to all team hobbywing with champ result. we hope also have a chances to test new SW in soon ...
smilekt is offline
  #3438
smilekt's Avatar
Originally Posted by AGNO
Congratulations, great victory!
We are awaiting the release of the new FW
mee to
smilekt is offline
Old 03-01-2011, 04:23 AM
  #3439
Hi Guys
regards Angelo
Thanks man. Nothing grammatically wrong with the previous instructions/feature names, but I think they were f*cked up (I still don't understand!!). Had to study here....
Appreciate the efforts
cheapskate.brok is offline
Old 03-01-2011, 04:49 AM
  #3440
Nice! I hope the brake delay option is also introduced
Gusi is offline
Old 03-01-2011, 05:00 AM
  #3441
hi all , my dads been running a h/w 21.5 motor the problems he has is the motor temp is bout 80c +
from these settings is there a way to get the motor so it dont run as hot.
drag brake 0%
drrs 7
brake force 100%
reverse 100%
initial brake 100%
neutral range 6%
boost timing 28
turbo slope 18
turbo timing 30
start rpm 5000
turbo delay 0.3
timing acc 350
gearing is 4.98 on a xray t3
heres a video of the track
http://www.youtube.com/watch?v=IPq7u...eature=related
thanks
mwoods is offline
Old 03-01-2011, 05:10 AM
  #3442
cherry2blost's Avatar
drag brake 0%
drrs 7
brake force 100%
reverse 100%
initial brake 100%
neutral range 6%
boost timing 28 40
turbo slope 18
turbo timing 30 18
start rpm 5000
turbo delay 0.3
timing acc 350 500
thanks
Try that for size........
Or if he is very throttle heavy (ie hits Full throttle regularly)
Try 58 Boost and NO TURBO on your original 350 setting.....
cherry2blost is offline
Old 03-01-2011, 06:09 AM
  #3443
kschu's Avatar
Trader Rating: 16 (100%+)
the new software come with few version...3 new version...
110125,110211,110213,
kschu is offline
Old 03-01-2011, 06:41 AM
  #3444
Tabushi's Avatar
How do i get version 508 ?
thanks
Tabushi is offline
Old 03-01-2011, 07:07 AM
  #3445
Originally Posted by 2 Bar Boost
I run on asphalt track, 1:10 fwd schumi mi3.5, fdr 5.0. The track has two 20 m straights and tight in field.
Thanx
U were running on foams right?
What was ur rollout?
SeanV is offline
Old 03-01-2011, 07:08 AM
  #3446
he can be , ill give that a try at the next meeting thanks .
mwoods is offline
Old 03-01-2011, 11:33 AM
  #3447
JRXS_chris's Avatar
Hi guys, enjoying the thread. There's some great info on here. I'm after some advice on how to setup my xtreme stock using a 10.5 (using a LRP x11 for the zero mechanical timing) on a large, flowing track. Anyone come up with a setup I should try? Thanks
JRXS_chris is offline
Old 03-01-2011, 01:10 PM
  #3448
sosidge's Avatar
thanks
It is still part of the current 119 software download.
sosidge is offline
Old 03-01-2011, 03:49 PM
  #3449
Trader Rating: 24 (100%+)
Just recently got a Hobbywing Xerun Extreme stock 60A esc with a 17.5 as a combo. I'm however going to be using this in a STRC LCG 2wd Slash for some off-road racing. Is there a Xerun thread for off-road setups? Anyone have a recommendation on a good starting point for my application?
rcuser67898578 is offline
Old 03-01-2011, 03:54 PM
  #3450
venom54's Avatar
Default TEMP ON 21.5
drag brake 0%
drrs 7
brake force 100%
reverse 100%
initial brake 100%
neutral range 6%
boost timing 28
turbo slope 18
turbo timing 30
start rpm 5000
turbo delay 0.3
timing acc 350
thanks
Results for Sunday night 26/02/11 at a local track SERCCC (Melbourne Australia) on a flowing track setup. Three speed portions and four tight/hairpins sections. New set up on ESC only.
Car - XRAY T3 2011
FDR - 4.91 (To low for 17.5)(better at 5.5 and up)
MOTOR - SP21.5 V3 SET TO ZERO DEGREE TIMING (Second motor used, first was fried due to incorrect settings)(blame the pit dude (me))
BATTERY USED - YUNTONG 5000 40C
TYRES - MUCHMORE 32 pre mounts.
RADIO - Futaba 2PL
BODY - HPI MAZDA 6
CAR SETUP - Kit standard with a change to droop on rear, more droop.
SETTINGS USED ARE LISTED BELOW ARE THE NEW SETTINGS FROM 26/02/11.
1 = 1
2 = 0%
3 = 3.4V
4 = 9
5 = 100%
6 = 25%
7 = 0%
8 = 6%
9 = 35
10 = 24
11 = ENABLED
12 = 24
13 = 3000
14 = 0.3SEC
15= 750
Results were great acceleration and very good top end. Motor temps stayed around 55 degree. Fastest lap for 21.5 class. Driver (Michael Clark) is only new to this class with 6 rounds at this club and now sitting second overall.
More setups to follow. Hope these setup options will be of help.
Cheers
Ren
venom54 is offline
