Team Associated RC8Be Thread
#2462
Although going by the motor mount i'm sure the Grid one will be pretty sweet.
#2463
#2465
http://www.integy.com/st_prod.html?p...75&p_catid=113
+1!!
#2466
#2468
Hey guys just wanted to put a feeler out there. I just came up on about 12 or 13 sets of used tires. An assortment of Pro-Line Crimefighters and Bow-Ties and a bunch of Panther tires (not as familiar with Panthers line-up of tires). None of them is less than 90% tread remaining with the majority being at 95% or better. Just wanted to gauge interest on this thread since were all a little more familiar with one another. Would there be any interest in this lot of tires? Maybe $20 or so per set if someone wanted them all??
#2469
#2470
You can use the stock screws if you use the diff riser. I'd just build it with the diff riser and Grid mount, then when you get the shorter screws in, remove the diff riser, and install the shorter screws.
#2472
#2474
