Team Associated RC8Be Thread >
Old 02-07-2011 | 03:55 PM
  #2311
schnellschnell's Avatar
Originally Posted by GreggW
Who's going to be first?
I've had that page open in a tab for a few days now. That is all I need. Haven't even got my transmitter yet.
It is fun buying all the nice parts. Would take off a fair bit of weight.
j
schnellschnell is offline
Old 02-07-2011 | 03:56 PM
  #2312
carbon chassis for the rc8be?
agarabaghi is offline
Old 02-07-2011 | 04:03 PM
  #2313
117's Avatar
117
Originally Posted by rcjunky10
I've ran the Kyosho zeal tape for the past two years and it is phenomenal, the only drawback is that once you stick it's stuck.
You can get the tape off without too much residue if you work on it with a little elbow grease. It is very sticky, though. I really like it. Even if the RX8 doesn't really need the vibration/impact absorption, it certainly doesn't hurt to have it.
I thought about it, but I'd rather get feedback on the fit and finish. There were a couple (I think) of people that bought the chassis earlier in the thread and reported minor fitment issues. Hopefully those have been resolved. I also wonder if it's milled in the same areas as the stock chassis. If it's not milled under the spur gear area, you'll be forced to use the stock diff riser.
I was referring to my Eagle Talon, the AWD Turbo only gets 22 on the highway, and thats on a good day.
Ah, that makes perfect sense now. My wife's former car (Miata) got amazingly bad gas mileage for such a small engine and light car, 25 MPG!!
That is indeed what it is.
117 is offline
Old 02-07-2011 | 04:04 PM
  #2314
i don't see front diff milled areas... might just be the image..
Old 02-07-2011 | 04:09 PM
  #2315
SEF's Avatar
SEF
I've been using the same SNR carbon chassis for the RC8Be for some time now. Since August or September of last year. Search back on this thread and you can find some of my reviews and pics.
I really like the lighter chassis. It drives well, makes the car more nimble, and has withstood the punishment of practice/racing twice a week on both an indoor clay track (WCRC) and an outdoor large track (Revelation).
SEF is offline
Old 02-07-2011 | 04:23 PM
  #2316
GreggW's Avatar
This pic is of the bottom of the chassis.
The burning question is, is it milled out for the center diff like the stocker? some of us, namely Billy and I have removed our center diff risers.
GreggW is offline
Old 02-07-2011 | 04:38 PM
  #2317
117's Avatar
117
How is the fitment? I know it has the stock kick up in the front, but are the sides bent upward as well, like the stock chassis?
117 is offline
Old 02-07-2011 | 04:42 PM
  #2318
GreggW's Avatar
Took it out for a test drive Billy, I love it! Smooth, Smooth, Smooth!!
What isn't so smooth are my stocker Holeshots, which lasted 2 battery packs.
GreggW is offline
Old 02-07-2011 | 04:46 PM
  #2319
117's Avatar
117
Awesome Gregg! I knew you'd love it once you tried it. I couldn't believe the difference!
BTW, I ordered that aluminum servo horn. We really are going to end up with the same setups.
Were you able to change the settings on the RX8 using the HotWire without any issues? What settings are you using?
117 is offline
Old 02-07-2011 | 05:00 PM
  #2320
GreggW's Avatar
I was able to get the software updated correctly, and after that I didn't plug the hot-wire back in. Lol so it's running all factory settings. I can't even imagine this thing on 6S! And I don't even have the timing up on it. Max motor temp observed with body on and no cooling holes was 108. ESC was 92. Ambient temp 67.
And Billy I just got my "smaller" servo horn in. And for some reason, it's the same size as my old one. Even though it's $2 cheaper. I'm starting to think they put the wrong one in the package.
GreggW is offline
Old 02-07-2011 | 05:26 PM
  #2321
K-Line's Avatar
So i just got my new RC8Be and im just wondering what size pinion i should use. Its a 2650 on 4s, im just looking for a size good for all use on different size tracks. Thanks
K-Line is offline
Old 02-07-2011 | 05:42 PM
  #2322
GreggW's Avatar
Tires, pinions, shock and diff oils and suspension setups should be dialed for each track. There is no one single pinion 10 different tracks. With that being said. Try a 19tooth mod 1 pinion.
GreggW is offline
Old 02-07-2011 | 06:00 PM
  #2323
GreggW's Avatar
GreggW is offline
Old 02-07-2011 | 06:02 PM
  #2324
im running on 17t pinoin, and im not sure if i would go higher. Temps are around 150/160.
Old 02-07-2011 | 06:07 PM
  #2325
117's Avatar
117
So the one you received today looks like the one above?
That doesn't look like the picture on Tower's site for the "short" horn:
And Gregg, I feel your frustration. The custom face plates that were shipped on the 27th still aren't here. They were delayed due to the crazy weather last week. They were out for delivery this morning, but now the tracking number shows another exception. I wonder what the problem is now...
This weekend, I pressed a few bushings out of my spare lower control arms to install my backup set of spherical bearings. As fate would have it, some of the bearings were the wrong size. Ugh. Contact the vendor today, he sends me drawings and asks me to confirm. Not only do the bearings I have differ from the drawings, but they aren't even the same dimensions as the stock bushings! ARG!! These bearings aren't cheap either; not cheap by any means. So now it looks like I'm going to go order another full set of lower control arms and just use the stock rubber bushings for now until I can get this bearing issue sorted. I'd replace the bearings in my current control arms, but they were custom made and the bearing adapter shells are spot and tack welded into the control arms. I'm thinking I'm going to have to grind the welds, press the bearings out and replace them. This off-the-shelf bearing kit doesn't look like it'll work as nicely as this custom setup I have. ugh...
117 is offline
