RC10B4.1 FT/WC
#1472
#1473
well i just tried the t4 chassis with buggy setup. Works pretty well. I would say its alot more stable high speed and in turns. It felt like the more i pushed the car in the turn the more it wanted to turn. I run on a small tight high bit indoor track. I wish it would turn a little sharper. For me it was alot easier to drive but where its tight was alot harder to hold the tight line. About the same lap times just a little more consistent So im just going to run the normal chassis. You guys should try it you might like it more.
#1476
Good start,I know guys that run 26 and some run a 29,depends on boost and timing on motor,I'm in the sAme boat,I just switched to team icon motors and there alittle different then tekin motors
#1478
Tighten down that servo saver! I glued mine and tightened it all the way when I ran the 4.1 and it felt much smoother throughout the turn, especially long sweepers.
#1480
My bad, 81. AE says 81/23 for a 9.5 which is close to 4600kv. I don't think your gonna have to drop to down to an 18-19....
#1481
#1482
I usually dremel a little out of the top plate where the rack goes through, or like weazel said tighten it down. If you start breaking the saver consider loosening it back up and trying the dremel idea
#1483
...be sure to make the difference up out on the steering blocks so your bump steer doesnt change.
