Team Associated RC8Be Thread >
Old 01-22-2011 | 12:23 PM
  #1381
GreggW's Avatar
Originally Posted by Team Grid RC
All RC8 mounts are now shipping with the new GRID engraving.
Ron
Awesome, thanks Ron! Look forward to it! They look 100% better.
GreggW is offline
Old 01-22-2011 | 01:30 PM
  #1382
jmackani's Avatar
Originally Posted by GreggW
I may check one out to but the first time I have to send it back to get fixed, they can keep it. Ive heard of too many ESCs failing. 5 times back to Tekin is about 3 times too many.
With the new 3 hole case, you will not have to send it back.
jmackani is offline
Old 01-22-2011 | 01:34 PM
  #1383
GreggW's Avatar
I also wish the wiring was easier. That soldering is not as clean as the MMM
GreggW is offline
Old 01-22-2011 | 01:40 PM
  #1384
GreggW's Avatar
How long is it taking to get the Grid mounts from Canada?
GreggW is offline
Old 01-22-2011 | 01:46 PM
  #1385
117's Avatar
117
Mine took less than a week. Pretty quick from CA, IMO.
The soldering is one thing I really dislike about the RX8. I'd much rather have connectors like the MMM.
Any pictures of the new and old Grid logo?
117 is offline
Old 01-22-2011 | 02:08 PM
  #1386
jmackani's Avatar
Soldering is a piece of cake. Follow this video and it will never be a problem. Those posts also act as heat sinks.
http://www.teamtekin.com/videos/rx8-solder-video.html
jmackani is offline
Old 01-22-2011 | 02:11 PM
  #1387
jaybird95's Avatar
I ordered mine on the 15th and I still havent recieved it. (so cal)
jaybird95 is offline
Old 01-22-2011 | 02:12 PM
  #1388
GreggW's Avatar
Grid is in Toronto Canada. And scroll up Billy. Pics are posted, I think on the last page.
So that's been 7 days so far. I'm expecting 10-12 business days.
GreggW is offline
Old 01-22-2011 | 02:21 PM
  #1389
117's Avatar
117
Soldering is easy, no doubt, but not as clean as connectors, IMO. I still find it interesting that RC has so many connectors that rely on solder for the electrical and mechanical connection (eg Deans, Traxxas, etc). I hardly see any crimping except for servo connectors.
I never soldered any connections during my time in the military. Everything was crimped and sealed. Same goes for most race cars. Not much wiring is soldered.
117 is offline
Old 01-22-2011 | 02:26 PM
  #1390
117's Avatar
117
Do you guys usually cover the RX8 posts with shrink?
Also, sorry to hear you guys are waiting so long for the mounts. Mine came pretty quick.
117 is offline
Old 01-22-2011 | 02:42 PM
  #1391
jmackani's Avatar
No, do not cover them with shrink wrap. That can take away the heat dissipation capability. That is part of why I do not like the connectors so much. Seeing those even with shrink wrap over the bullets looks like too much movement with the possibility of them touching together. Soldered there really is not room for movement. I only have one system in an sct with bullets and they have been good so far though. I am not taking my systems and swapping motors out either, so I do not need that flexibility. The bullets just make the wiring look bulky to me. Nothing better than a direct connection. I was also in the military and higher end electonic connectors are soldered and not crimped. My better solder skills were learned through 2m micro miniature training while in the Navy. Depends on the field that you specialized in.
As for shipping, just remember that customs has no rush to get things done. It's not the shippers fault.
jmackani is offline
Old 01-22-2011 | 03:00 PM
  #1392
jaybird95's Avatar
Post
I know its only been 7 days but I'm just so anxious, like a little kid.
  #1393
b_recliner's Avatar
great video
b_recliner is offline
Old 01-22-2011 | 03:06 PM
  #1394
At the board level sure.....but crimp is the preferred method at connectors.
305997 is offline
Old 01-22-2011 | 03:07 PM
  #1395
117's Avatar
117
Questions??
What kind of connectors did you work on that were soldered? I was an aircraft electrician in the TXARNG. I mostly dealt with cannon plugs and wire repair. Everything was crimped.
Almost everything I've worked with on my track car has been crimped with the exception of the connectors for my digital dash. It used a very small DIN like connector for use with 22ga and 24ga wire (those solder cups were small!).
I also don't like the use of bullet connectors for the motor for the reason you describe. I just would like the RX8 to have the same type of connectors used on the MMM (the bullet connectors are on the ESC itself).
117 is offline
