The Speed Passion Thread
#5896
What I'm trying to get at is simply, does the capacitor ONLY affect the braking power of the speedo?
If so, I won't need to change mine cos I've got plenty of brakes
If, for example, it gives the boost profiles more power or something then obviously I'll look to change it out!
Thanks for the other info though
Oli
If, for example, it gives the boost profiles more power or something then obviously I'll look to change it out!Thanks for the other info though
Oli
If the capacitor is polarised and soldered on the battery wires correctly (plus to battery plus) it is used to store a bit of charge which is released abruptly to compensate the battery voltage if it is momentarily depleted during hard acceleration or brake. Otherwise, no idea.
#5897
Oli
Oli
And thanks SAN
#5898
I've been away from Speed Passion for a while (since my LP 1.5's - which are still running strong in my off road mod vehicles). Anyway, I'm really thinking of picking up the new EX for my 17.5 1/12th scale. Is the only way to get to the advanced features with the new LCD box ? The stock box does not allow changes to these upper settings, correct ? Thanks.
The GT2.1 EX...came installed the 205g software which is for MOD motor use, no SUPERCHARGER feature on that verison of software. Then we have 528STOCK and 528MOD along with the no timing software = 508_no_timing for user to upload and use....
In order to upload the software onto the ESC, you will need the LCD box. So...the LCD is a good investment for you, that box itself can also replaced the plastic programmer box that came with the ESC.
Some ppl might have friend that has the LCD box, then you can have him to upload the software for you and then you can use the plastic box for adjustment. Once the SUPERCHARGER software is uploaded, the plastic box can adjust all 15 functions.
#5899
this 528stock has turbo I suppose? And can be used for the GT LPF 2.0?
#5900
#5901
Go here: http://www.speedpassion.net/us/produ...802LPFcb&c=ESC
...and you can see the applicable downloads for the 2.0LPF. You'll see the 528 software under the 7/8/2010 date.
#5902
Here's a bit more help if you don't know where to navigate...
#5904
I was wondering if anyone has run into the same issue that we have with our 2.0Pro in our Mod (version 3 4.0T) touring car.
Lights on esc are as per instructions on full gas and full brake, but after having used the car the esc light blinks green when on neutral. According to instructions there should be no light on when in neutral.
Have tried reprogramming radio to esc and also changed sensor wire and these had no effect on the issue.
Even when the light blinks on neutral the car is running normal.
#5905
@ Solara
I know that GT 2.0 has constant 400 A and burst 800 A, so with GT 2.1 Pro stock how many amps for constant and burst ? before... I installed friend's T3 with GT Pro stock 2.0 with 4 small capacitors and 12 awg cables ...and when i received my new GT Pro stock 2.1 , I only received 1 medium size Capacitor and 14 awg cables....any differences on performance because I haven't install it yet..
Thanks,
Bijono
Thanks,
Bijono
#5906
#5907
#5908
@ Solara
Thanks,
Bijono
Thanks,
Bijono
The GT2 PRO (not pro stock) used the 4 caps and 12ga wire simply because the PRO unit is mainly use with MOD motor...if you are going to use the 2.1 ProStock with MOD motor like 7.5 or 8.5T, you should upgrade the wire to 12ga and the 4 caps...
GT2.1 ProStock is aimed for stock motor racing...but it can be use with 7.5 and 8.5 with the right software.
#5909
The cool thing is... If you just load 528_Stock on the GT 2.0 Pro, it works perfectly fine for stock too! The new upgraded power capacitor that Solara had mentioned before is also a very good upgrade for stock racing.
-Korey
-Korey
#5910
57Likes
