Houstons Engine Service H.E.S.
#3992
I'm reading through and figured I'd jump in and hopefully offer a little help, Sean.
I'm no engine pro but if it was me, and my top shelf engine was acting silly, I would definitely send it to a good engine guy for a full rebuild and a medium pinch... whether it needed it or not. A Toro Nero Team deserves some real love.
Also, racing engines do have a lifespan like racehorses. At some point they just won't perform when pushed unless you replace everything. It's better to just retire it and buy a new one. Flame outs, big bearing leaks, tank leaks...you've probably overheated it quite a few times...when you take the tine out of the metals it's pretty much game over for that engine. A good engine guy will tell you whether or not you're just "kicking a dead horse."
EDIT: you're a .12 nitro TC Champ so you probably already know this stuff. Didn't mean to insult your intelligence if my input didn't help.
#3993
Sean
#3995
OK Update I just ordered a new front bearing along with a new conrod and wrist pin clips. I have gone ahead and removed the current bearing and let me tell you it is not hard to see that it was not doing it's job. You can see in the photo's that it was allowing dust to pass the seal along with air which has been causing my running issues.
Thanks Monty and everyone else with helpful idea's.
Sean
Sean
#3996
the reason front bearings go bad is from running your engine grossly rich on the low speed needle especially during break in . when the engine gets loaded up with excess oil and there is low crankcase pressure its ok , when you build crankcase pressure through increased rpm's the excess oil follows the path of least resistance . even the best front engine bearing on the market cant withstand that
break in of engines should be done as only slightly rich from race settings , aprox 2-3 hrs each needle
or where the desired temps are reached
and that front bearing was definitely leaking
#3999
there were a few of those that had some cranks that were opened up too far in the duration (trailing edge) resulting in loss of top end
fix; new crank
#4001
How much slop is acceptable slop in a front bearing? When the crank is held by both the front and rear bearing on my N21R, I cannot move the crank at all, but when I pull the crank out and reverse it (ie have it held by the front bearing only) I can then tilt it a few degrees. Addtionally, there is a gap between the shield and the inner cage so i can see some light through it, but then again how big a gap is a bad gap compared to "functional" slop?
Thanks,
Paul
#4002
in my findings over the years , the biggest sign of a bad front has literally came from excess oil leaking out the front bearing . when i pull the crank , which i tear my engines aprt for inspection fairly often , i am looking for some rust discoloring on the crankshaft that lets me know that the bearing has been seizing , bad bearing or just need cleaned out , reassembled and oiled if thats the case .
#4003
I recieved my Houston Tuned p5 today.
Monty put that double sealed front bearing in it, and silicone filled the crank..
I couldn't stand it so I put the engine in my trusty back up 808 tonight, and broke it in, mostly...
I followed you advice Monty and did the two idle heat cycle tanks, and so on...
Let me tell you guys something if you don't already know, This p5 absolutely rips. It sounds ready to take on the big boys....
The bottom end was instant, yet came on smooth through the midrange, and sang a wonderful tune on the top end too.
It's tough to explain, while running through the turns, of the parking lot, hehe.. When I let off power while still moving at medium speed, when I get back on it, it's just there, so it makes it easier to drive fast...especially through technical sections.....
Bonus: It's the easiest to tune engine I've ever had, and I've had a few....Idles low, never died, sputtered or coughed, he...
Now I've never had a "tuned"
engine before, but in dealing with Monty to the finished product, I'm freakin excited...
Oh yeah, I think a tank lasted about 13 minutes, if I loose a couple minutes after final breakin that's at least 11 minutes of runtime......Unless I'm just crazy.
A big thanks to Monty, and all the guys who get the word out about his work...
engine before, but in dealing with Monty to the finished product, I'm freakin excited...Oh yeah, I think a tank lasted about 13 minutes, if I loose a couple minutes after final breakin that's at least 11 minutes of runtime......Unless I'm just crazy.
#4004
sorry paul , i meant to answer your Q earlier but.......... well sometimes an elephant forgets
Thanks,
Paul
PS: my crank does show the symptoms you are talking, ie discolored rust spots where it rests on the front bearing. Sounds like I need a new front bearing indeed. Of course I don't have the gear to do it myself. I'll try to find a local solution as last time I shipped a mill for a rebuild to the US it took me about 2mths to get it back since the US customs went completely anal about it
#4005
but not sure it needs it though
22Likes
