NOVAROSSI Engine thread....
#571
Hi there, just have a quick question about my Nova.
i have the Nova 367 and it has the standard button on it. Would it be worth it to find a turbo button to put on it? Was just wondering cause that way I don't have to keep two kinds of glo plugs on hand at the races. TIA
#572
The team edition has a few upgrades. I think the differences are the Team has a ceramic bearing ect. Anwyays, here are some links so you can compare the 2
Team: http://www.amainhobbies.com/product_...ine-Turbo-Plug
Buggy Tuned: http://www.amainhobbies.com/product_...ine-Turbo-Plug
Hope that helps.
.Team: http://www.amainhobbies.com/product_...ine-Turbo-Plug
Hope that helps.
Thanks.
#573
break in 190-210° , racing after break in 225-270° is safe
the differences between the buggy tuned and team is
team : ceramic rear bearing , cnc machined piston (great improvement) ,15007t crank , new 2.5mm lowered head with oring supported head button .335$
buggy tuned : steel rear bearing , standard microcast piston , 15009t crank instead of 15007t, comes with standard and turbo head button still 280$
#574
yes , part number is 28011 i believe
so is the buggy tuned still a good motor and has the good run-times that i have been hearing all should i get the team version
#576
looking and i hear ur stoked atm wit ur baby was looking for a heart for me truggy the run-times these get are fantastic but i hear the toro nero is good as well
#577
I've problem with my plus4c team (I wrote with this in novarossi plus4 thread)
My plus4c team is after 3 gallons and my runtime is 5-7 minutes with 6,5mm venturi. My pipe is 9901ss and 41021 header. Os p4 plug. Temp about 240*. it isn't over.. I don't have power on top. with that temp. and 6,5 venturi. Engine has still compression.
Has somebody the same problem than me ? I don't know what can I do with it
#578
I couldn't stand it. Bought the FMS for my 808. Wow. Easy break in, smooth power and it has what it takes. It makes the sweetest sound on the pipe. 9853 pipe, short round nova header. Its still breaking in too. 7mm restrictor sounded about right to me. When this thing is ready it's going to fly....Hats off to Jim and Chris at Nova USA......Bring the rain.....
#579
#580
#581
I just replaced the front bearing on my N21BF (first time i've had an engine apart) and am now attempting to reassemble the engine. I noticed that the head button has an arrow on the top, but I did not pay close attention to what direction it was facing when I took it apart. Should the arrow face the exhaust port, or the carb?
Thanks in advance.
Thanks in advance.
#582
Thanks in advance.
Thanks in advance.
#583
Engine is a .21r limited hsn 3.5 out, lsn 4.5 out(both might be an hour either way). Half gallon on engine.
Getting three different rpm ranges after let off. First higher one lasts about 2 sec, next one lasts about 2-3 sec, then a smooth low throttle. Any sugesstions what to do with idle? Richen hsn and lean lsn?
Off to read the tuning bible again...
#584
very very close with most pipes
hope this helps
and the guy getting only 5 - 6 min. runtime , i can guarantee you with 100% accuracy that it is not your engine and you got something else going on in the car
guarantee it or i'll eat my shorts
#585
Thanks, will try that.
high speed 3.75 and low speed 3.75 , idle screw opened 1 full turn from just closed
hope this helps
hope this helps
352Likes
