Like Tree352Likes
NOVAROSSI Engine thread....
Old 07-20-2010 | 03:55 PM
  #571
StillH20 Racer's Avatar
Hi there, just have a quick question about my Nova.
i have the Nova 367 and it has the standard button on it. Would it be worth it to find a turbo button to put on it? Was just wondering cause that way I don't have to keep two kinds of glo plugs on hand at the races. TIA
StillH20 Racer is offline
Old 07-20-2010 | 05:51 PM
  #572
Originally Posted by nitroRCs
The team edition has a few upgrades. I think the differences are the Team has a ceramic bearing ect. Anwyays, here are some links so you can compare the 2 .
Team: http://www.amainhobbies.com/product_...ine-Turbo-Plug
Buggy Tuned: http://www.amainhobbies.com/product_...ine-Turbo-Plug
Hope that helps.
Thanks mate. I got a new Plus 4c Team and i should start to break in the engine soon. What i would like to know is what is the min. and max temperature for this engine to run well.
Thanks.
marco cianfrone is offline
Old 07-20-2010 | 07:23 PM
  #573
houston's Avatar
yes , part number is 28011 i believe
Thanks.
break in 190-210° , racing after break in 225-270° is safe
the differences between the buggy tuned and team is
team : ceramic rear bearing , cnc machined piston (great improvement) ,15007t crank , new 2.5mm lowered head with oring supported head button .335$
buggy tuned : steel rear bearing , standard microcast piston , 15009t crank instead of 15007t, comes with standard and turbo head button still 280$
houston is offline
Old 07-20-2010 | 07:33 PM
  #574
mrbusta's Avatar
so is the buggy tuned still a good motor and has the good run-times that i have been hearing all should i get the team version
mrbusta is offline
Old 07-21-2010 | 03:27 AM
  #575
mp9er's Avatar
Post
hey there you crim whats up the answer is yes you should get a team plus 4
mp9er is offline
Old 07-21-2010 | 04:30 AM
  #576
mrbusta's Avatar
crime and fingers in all pies here lol just
looking and i hear ur stoked atm wit ur baby was looking for a heart for me truggy the run-times these get are fantastic but i hear the toro nero is good as well
mrbusta is offline
Old 07-21-2010 | 08:01 AM
  #577
Busterlbn's Avatar
I've problem with my plus4c team (I wrote with this in novarossi plus4 thread)
My plus4c team is after 3 gallons and my runtime is 5-7 minutes with 6,5mm venturi. My pipe is 9901ss and 41021 header. Os p4 plug. Temp about 240*. it isn't over.. I don't have power on top. with that temp. and 6,5 venturi. Engine has still compression.
Has somebody the same problem than me ? I don't know what can I do with it
Busterlbn is offline
Old 07-21-2010 | 11:51 PM
  #578
merdith6's Avatar
Default FMS Blissssss
I couldn't stand it. Bought the FMS for my 808. Wow. Easy break in, smooth power and it has what it takes. It makes the sweetest sound on the pipe. 9853 pipe, short round nova header. Its still breaking in too. 7mm restrictor sounded about right to me. When this thing is ready it's going to fly....Hats off to Jim and Chris at Nova USA......Bring the rain.....
merdith6 is offline
Old 07-22-2010 | 06:54 AM
  #579
Are you sure your end points are set correctly? Should be getting better economy than 5 minutes. Running for breakin? Sounds like you may have the needles set way out of whack. I would try starting over with needle settings back to factory.
3DRCRACER is offline
Old 07-22-2010 | 07:34 AM
  #580
Busterlbn's Avatar
Yes, I'm sure.
After breakin it was the same.
I'll try with factory settings, but if someone has another idea let him write.
Regards,
Dorian
Old 07-22-2010 | 10:11 AM
  #581
I just replaced the front bearing on my N21BF (first time i've had an engine apart) and am now attempting to reassemble the engine. I noticed that the head button has an arrow on the top, but I did not pay close attention to what direction it was facing when I took it apart. Should the arrow face the exhaust port, or the carb?
Thanks in advance.
sdtech58 is offline
Old 07-22-2010 | 11:17 AM
  #582
merdith6's Avatar
Default The
Thanks in advance.
Arrow faces the exhaust......
merdith6 is offline
Old 07-22-2010 | 02:48 PM
  #583
Engine is a .21r limited hsn 3.5 out, lsn 4.5 out(both might be an hour either way). Half gallon on engine.
Getting three different rpm ranges after let off. First higher one lasts about 2 sec, next one lasts about 2-3 sec, then a smooth low throttle. Any sugesstions what to do with idle? Richen hsn and lean lsn?
Off to read the tuning bible again...
Failedabortion is offline
Old 07-22-2010 | 03:01 PM
  #584
houston's Avatar
high speed 3.75 and low speed 3.75 , idle screw opened 1 full turn from just closed
very very close with most pipes
hope this helps
and the guy getting only 5 - 6 min. runtime , i can guarantee you with 100% accuracy that it is not your engine and you got something else going on in the car guarantee it or i'll eat my shorts
houston is offline
Old 07-22-2010 | 03:42 PM
  #585
Thanks, will try that.
hope this helps
