Like Tree18Likes
Xray NT1
Old 06-24-2010 | 01:12 PM
  #5386
DS Motorsport's Avatar
Originally Posted by Speedypeterb
from the looks of the pictures did the sway bar rub the cvd
Didn't rub anywhere, the anti rollbar has about 2mm of space in every direction.
DS Motorsport is offline
Old 06-24-2010 | 05:52 PM
  #5387
Riketsu's Avatar
Hey DS,
Did you have to machine down the bulkhead where the red wire holders sit? Or did you just have to cut the upper bulkhead (bearing covers).
Riketsu is offline
Old 06-25-2010 | 10:56 AM
  #5388
Originally Posted by Riketsu
Hey DS,
I had to machine the sides of the bulkheads where the red bushings are sitting, just did it with a dremel tool though.
Also had to cut a groove were the wire sits in and drill 2 holes with m3 thread for the wire.
The upper part of the bulkheads didn't need modification.
Also made 4 holes with m3 thread on the sides of the lower and upper bulkhead to mount two carbon brackets for stiffness.
When I really like the system and it is faster as the stock system I will have a set of bulkheads and the carbon parts machined professionally, now I did everything with a dremel tool.
Old 06-25-2010 | 09:22 PM
  #5389
pearldiver's Avatar
Default upgrade parts for USD100 budget
hi guys need ur help here...
i have USD150 to spend at RCMarket, im looking for wise upgrade for the money. would someone plz list down which parts should i order for my stock NT1 2010, to improve my car performance/ durability?
* oppps now my balance to spend is only USD100 coz i need to order CSO 3.1mm 7075 hardcoated chassis to replace my slightly bent chassis.
-to exclude wheel hub coz already upgraded
pearldiver is offline
Old 06-27-2010 | 10:36 PM
  #5390
HPIRacer79's Avatar
speak to team driver from Aus "mrgsr", he will get your car dialed.
HPIRacer79 is offline
Old 06-27-2010 | 10:41 PM
  #5391
To be honest the only true upgrades for the NT1 are: in no particular order:
lightweight middle shaft
lighteight front shaft
yellow clutch shoe
light weight brake disk adpater
1 degree front knuckle arms
0.7 front sway bar soft
km racing brake pads
mrgsr is offline
Old 06-27-2010 | 11:13 PM
  #5392
PDX-Spike's Avatar
yellow clutch shoe
Umm, what about the lightweight clutch bell?
PDX-Spike is offline
Old 06-27-2010 | 11:17 PM
  #5393
I have been using the xray aluminium bell with good success..
i was going to mention clutch but it would not have fit the budget..
i have just received the xca clutch and will be testing that this weekend so ill report back on it then.
mrgsr is offline
Old 06-27-2010 | 11:22 PM
  #5394
yellow clutch shoe
i would of dropped the light weight brake disk adaptor bro and added the alumium clutch bell in a flash. the bell is night and day compared to the crappy steel one.
TomB is offline
Old 06-28-2010 | 01:23 AM
  #5395
pearldiver's Avatar
Thanks guys for the ideas... it will make my decision easier. i'll have a look at those items & see if i need to stretch my budget a bit. regarding alu clutch bell, anybody here have same experience as TomB?
Old 06-28-2010 | 04:29 AM
  #5396
aluminium clutch bell is awesome
you just have to watch the wear on them
i would prefer the xray steel lightweight/ventilated
mrgsr is offline
Old 06-28-2010 | 06:58 AM
  #5397
RC MARKET's Avatar
XRAY Released 2 option parts
& Low Friction belt V2
Attached Thumbnails Xray NT1-xr-333051.jpg   Xray NT1-xr-335721.jpg   Xray NT1-xr-335431v2.jpg   Xray NT1-xr-335442v2.jpg
RC MARKET is offline
Old 06-28-2010 | 08:35 AM
  #5398
PDX-Spike's Avatar
This is the clutch bell I was referring to. Works great, no problems. On my third season with it.
Old 06-28-2010 | 08:56 AM
  #5399
Tag's Avatar
Tag
hi guys, just bought a LRP .12 team spec engine, just wondering if this enigne will fit into nt1 without modification , i am asking because i had fitment problem with a sirio evo4, thanks !
Tag is offline
Old 06-28-2010 | 12:19 PM
  #5400
R3VoLuTiOn's Avatar
what was the fitment issue?
my evo3 wasnt close to any fitment issues.
R3VoLuTiOn is offline
