Like Tree7Likes
Old 06-16-2010, 04:23 AM   #5356
RayJ's Avatar
Congrats to Paul Lemieux for his win at the ROAR Nats in sedan, and Ralph Burch for his TQ. Don't know what happened to Ralph's car early on in the main, but these two have been laying it down all over! These guys are always helpful, and supportive to racers at every event I have been to. Hopefully next year I will get a chance to race the nats..... and just race more often.
RayJ is offline   Reply With Quote
Old 06-16-2010, 06:00 AM   #5357
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Yup, congrads to Paul. Couldn't have been won by a nicer guy!
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 06-16-2010, 07:20 AM   #5358
D-nicest's Avatar
Originally Posted by TeamCarnage View Post
Great Racing! You gonna make the Byrons Race at Leisure Hours, Joliet IL? It would be worth another trip!
Let's see I may be able to make that race. I know A bunch of people from around here are planning on attending as well.
Diatta Collymore [email protected]([email protected])(www.fordhamhobbies.com) (Wallacemotorsports.net) Fordham Hobbies, Wallace Motorsports, WRC Racing, Hot Race Tyres, Ielasi Tuned Engines, VP Power Master fuel, KO Propo America, Paint By Mikey Mike
D-nicest is offline   Reply With Quote
Old 06-16-2010, 08:46 AM   #5359
i know its a big ask,
but can someone measure the width or the front diff..
from 1 bearing to the other bearing.
TEAM DURANGO CARBON DEX210 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
TEAM DURANGO CARBON DEX410 - POWERED BY TEKIN RS PRO/REEDY SONIC 17.5
TEAM ASSOCIATED B5 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
LiL_JaSoN is offline   Reply With Quote
Old 06-16-2010, 11:18 AM   #5360
DS Motorsport's Avatar
Inside bearing to inside bearing: 31.90
Outside bearing to outside bearing: 39.90
Outside eccenter to outside eccenter: 41.90
Gotta love CAD-programs.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 06-16-2010, 05:44 PM   #5361
what do you mean by 'eccenter'? is that with the bearing hub on?
just want to know outside to outside
also the weight of the diff? and weight with xceed lightweight gears, and cups
Old 06-16-2010, 07:19 PM   #5362
lil-bump's Avatar
Trader Rating: 83 (100%+)
That's real close to a Mtx4r front oneway
The Mtx4r outside bearing to outside bearing oneway is 39.94
What about the rear diff measurement?????
Come-on fire up the machine again
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 06-16-2010, 07:41 PM   #5363
the one way measureed 42mm bearing to bearing on the RRR..
if anyone has a nt1 diff they dont need, im willing to buy it to try fit it in the rrr.
Old 06-17-2010, 06:15 AM   #5364
anyone kind enough to count the teeth in the rear diff?
Old 06-17-2010, 07:31 AM   #5365
lil-bump's Avatar
If you look at the Xray manual. The rear drive pulley on the nt1 is a 20 tooth.
And the Nt1 has a final drive ratio of 2.05 that means the rear diff pully should be 41 teeth. this is how I found it
If I'm wrong you'll let me know.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 06-17-2010, 03:45 PM   #5366
kmichael's Avatar
Default spool
What's a good wt for rear diff when running a front spool on high traction track
kmichael is offline   Reply With Quote
Old 06-17-2010, 04:44 PM   #5367
Eccenter is the adjustable cam which houses the bearing, it's eccentric, so called an eccenter.
The measurement shown in your picture is the bearing outside to outside measurement so 39.90.
I have the Capricorn diff gears and pins and Xray lightweight outdrives, but I forgot how much they weighed, it was around 20-25 grams lighter compared to a stock diff.
Edit: front diff 24 grams, rear diff 27 grams.
Would recommend the Capricorn diff gears if you want the plastic gears since they last and have been thoroughly tested, I've already seen multiple broken Xceed diff gears.
Rear diff is 28.6 outside bearing to outside bearing.
P1-RC.com
Old 06-17-2010, 05:01 PM   #5368
Btw this is what I'm currently working on:
I really dislike the blade-type ARB, and almost bought a Serpent just because of the front wire type ARB the 733 has.
When the Capricorn set was released I decided to go for it and make it work on the NT1.
Received the set yesterday and it seems to be more of a challenge as I thought it would be.
I still have to machine the sides of the bulkheads so I can fasten the red bushings and have to make some carbon sideplates so I can fasten the top sides op the front bulkheads.
Had to cut the front off so make space for the ARB, but lost the two front mounting holes in the process.
Also planning on cutting two carbon plates for the downstop adjustment.
Planning on testing the system this Saturday.
P1-RC.com
Old 06-17-2010, 05:09 PM   #5369
40K when you are a starting driver, 60K when you are an average driver and 80K when you are a pro.
With high traction tracks you should always try to increase the rear diff locking as this will give you maximum acceleration.
However with very thick rear diff oils the car only works when you are right on the racing line, 10 cm's off and the car will spin out, that's why I would recommend different oils for different skill levels.
P1-RC.com
Old 06-17-2010, 05:29 PM   #5370
kmichael's Avatar
