Xray NT1
#5388
Also had to cut a groove were the wire sits in and drill 2 holes with m3 thread for the wire.
The upper part of the bulkheads didn't need modification.
Also made 4 holes with m3 thread on the sides of the lower and upper bulkhead to mount two carbon brackets for stiffness.
When I really like the system and it is faster as the stock system I will have a set of bulkheads and the carbon parts machined professionally, now I did everything with a dremel tool.
#5389
hi guys need ur help here...
i have USD150 to spend at RCMarket, im looking for wise upgrade for the money. would someone plz list down which parts should i order for my stock NT1 2010, to improve my car performance/ durability?
* oppps now my balance to spend is only USD100 coz i need to order CSO 3.1mm 7075 hardcoated chassis to replace my slightly bent chassis.
-to exclude wheel hub coz already upgraded
#5390
#5391
lightweight middle shaft
lighteight front shaft
yellow clutch shoe
light weight brake disk adpater
1 degree front knuckle arms
0.7 front sway bar soft
km racing brake pads
#5392
Umm, what about the lightweight clutch bell?
#5393
I have been using the xray aluminium bell with good success..
i was going to mention clutch but it would not have fit the budget..
i have just received the xca clutch and will be testing that this weekend so ill report back on it then.
#5394
i would of dropped the light weight brake disk adaptor bro and added the alumium clutch bell in a flash. the bell is night and day compared to the crappy steel one.
#5395
Thanks guys for the ideas... it will make my decision easier. i'll have a look at those items & see if i need to stretch my budget a bit. regarding alu clutch bell, anybody here have same experience as TomB?
#5398
#5400
18Likes
