The Speed Passion Thread
#4667
I changed motors and sensor cables...could the capasitor becausing it?I will wait till next week and get my mate to flash the 422 into it and see if that fixes it....apart from that it must be a speedie issue..software or hardware I am not sure...but it never got hot
#4671
Hi,
When using the sp motor 17.5t and speedo with the 100422stock software what should the timing be set at on the actual motor ? does the speedo automatically take over the timing regardless of what it's set on the motor ?
Also on this link files.mibosport.com/200001241-5ea455f9ed/Supercharger%20Starting%20points dot pdf what are they refering to on items 1-8 under 17.5t ?
Nothing seems to match up with all thre documents
#4672
#4673
2. technically it's ok, but not quite safe, depend on which motor turn you run with. so keep watching the ESC temps, and never forgot to use your fan.
#4675
1. Put 528 back on and set as it was
2 Turn the Lipo cutoff to the off setting
3 Test the car.
If the car goes fine and does not slow down then you have a battery/connector problem or faulty esc.
If the car is just like before then you have a output problem. Probably a faulty esc or sensor wire plug.
Mike
#4677
Hi,
#4678
Hi,
#4680
It sounds as if it's hitting the lipo cutout, double check the voltage per cell is set right (3.0v) and that your batts are in good nic. Normally when the cap is stuffed all you get cogging when you mash the throttle
57Likes
