Xray NT1
#5281
do any of you have used the 30g xray weight that sits between the engine and battery? the thing is that i'm hesitating in using it, because of overweight, or by moving the center weight of the car backwards, don't know, need advises, i will also try to balance the card by adding weight to the pipe side of the car, i will use the mini scales in for wheels. i also got the ti pivot balls i think they are made by atomic rc, supposing that the steel ones and these ti ones, are exactly same size, which ones will you use?
i'm trying to save some wieght by using the ti pivot balls and for then adding the balance weight and the 30g xray weight, but i'm affraid will be too much wieght.
#5282
#5283
The front wheelbase is adjustable.
The top deck is a lot narrower which i believe creates more flex in the front, i am using a locker and i have a tonne of steering..when i ran the 08 i wasnt able to run a locker as it would understeer.
the belts are also 1mm wider to give you strength and reliability. Give ari a call at hei.com.au he has them in stock.
buy the kit and the blue soft springs front and rear, 2.2mm rear swaybar and if u like driving with a locker iw ould get that to xray make a super light front spool. otherwise run 150,000 weight front diff
call me if you have any other questions
#5284
#5286
FYI: Not sure if anyone else notices this or said somting but the large belt (the 390mm one) I believe is the same as a Losi JRX-S Pro but for around $5 less.
(I was trying to see if i could find belts that were less expensive for my JRX-S and thought u guys with the NT1's might save a little $$)
Losi part # is LOSA3302
3mm x 390mm belt, Grey in color.
#5287
Original nt1 belt is 396mm long ( 396mm divide by 3mm pitch = 132 teeth )
Losi belt is 390mm = 130 teeth
2 teeth difference is quite a lot. ..... u need to install it to make sure the belt won't over strecth.
The width is also important too.
Too narrow, the belt will skip or ruin easily.
#5288
are u sure it can fit ?
#5289
Is the width same ?
#5293
hi i saw a post by musti72 on another post saying that the nt1 multiflex engine mount doesn't really work that well and instead most racers have replaced it with the original one is it real? i have the multiflex one installed on my nt1 but i didn't test the stock one, what would be a better option regular one, or the multiflex?
#5294
18Likes
