EB Mods JS Engine
Old 03-29-2010 | 07:35 PM
  #436
toobad4u's Avatar
I picked up my motors and fuel @ 6:30 Friday morning from UPS, and headed to the Battle @ the Beach this weekend. Got the extras installed on them, and into the buggy. I had to grind down the right rear corner on the mounting area to it my Jammin X2 with the 1 piece motor mount. The 2 piece mount might be a different story. It didn't take a lot to clear, but I wanted a little clearance. Had to do the same thing to my V-spec, and have had no problems, so I do not expect any with this motor either.
I heated the motors, and then fired them up. They started right up, and ran great all weekend. One in my truggy was running a little rich, but I had my buggy motor right on the tune. Plenty of power, and mileage. I didn't run it till it was empty, but pitted around the 9 minute mark to be safe. Motor came off the track between 195-210 after the qualifiers, and mains. Seems to run pretty good around these temps.
I had to borrow a buggy for the 3rd round of qualifying, which was also equipped with a JS motor, since I broke an A-arm in round 2 on my buggy. I turned some good lap times with his borrowed buggy. ( maybe a brand switch is coming) I qualified 13th in the Buggy class out of about 30 entries, and 8th in Truggy out of 20. B main for the buggy, A main for the truggy. Finished in the same positions I started the mains in. I don't think it was bad for the 1st time out running a truggy at all.
I did have quite a few people asking info about the motors, so hopefuly there will be more JS engines heading to the southeast. Had a lot of fun, and am ready for more with these motors. Club race in 2 weeks, and then RC Pro Series opener. Can't wait!!!
Stephen
toobad4u is offline
Old 03-30-2010 | 11:12 AM
  #437
Radical Freaks's Avatar
Originally Posted by Peter Martin
The Team ran this weekend in SoCal. Temp. was 80 degrees. In the Mods we ran P6 plugs and P5s in the stock/race preps.
The engines ran better with the colder plugs and warm temps. Buggies and trucks pitted at 10 minutes.
Please try these plugs as we get into summer.
Hello There Peter,
Just receive my EB Mods JS fully Mod engines, ran it today at our local track........it is AWESOME !! Ran 4 tanks ....using 2035 tuned pipe, Force Turbo 5 glow plug, did all 4 tanks with 10 mins refuel.....
The engine comes with 0.3mm shim.......is this best suited for 30% Nitro Fuel?? Outside Temp. is mostly 30-35c....
Radical Freaks is offline
Old 03-30-2010 | 11:18 AM
  #438
jpalessi's Avatar
yes the engine comes shimmed for 25%-30% nitro.
Originally Posted by Radical Freaks
Hello There Peter,
jpalessi is offline
Old 03-30-2010 | 05:05 PM
  #439
JUD's Avatar
JUD
Hey Joe is the 086 still the best pipe? And with what restrictor? And plug? Thanks
JUD is offline
Old 03-30-2010 | 05:17 PM
  #440
jpalessi's Avatar
i'm running a dynamite 086hs with a P5 plug and a 7mm stack.
some of the team guys are running the NR 9901 with a short header and getting great results too. also P5 plug and 7mm stack.
jpalessi is offline
Old 03-30-2010 | 05:36 PM
  #441
JUD's Avatar
JUD
O.S. p5? Sounds good. Is that a cold-medium plug? Im using an OD plug and my temps are a little high.
JUD is offline
Old 03-30-2010 | 05:42 PM
  #442
rallyebmx's Avatar
Does the 9901 only come as the 'super strong'? Sounds heavy. The 086 is about an ounce lighter than most pipes
rallyebmx is offline
Old 03-30-2010 | 05:56 PM
  #443
jpalessi's Avatar
yes OS P5 it's a medium plug. I do NOT recommend the OD plugs
the current 9901 is the SS.. the original 9901 was like the old NR pipes.
jpalessi is offline
Old 03-30-2010 | 06:01 PM
  #444
madweazl's Avatar
What issues have you noticed with the OD plugs? Is it just a fit issue with the JS button?
madweazl is offline
Old 03-30-2010 | 06:05 PM
  #445
jpalessi's Avatar
I dont want to bash any companies or their products, but we found them to be too hot and inconsistent from one to the next. Till the JS factory has plugs we recommend OS P5's in the stock and Race prepped, and P5 or P6 in the full mod.
jpalessi is offline
Old 03-30-2010 | 06:10 PM
  #446
madweazl's Avatar
I've had great luck with them thus far but I'm only on my second plug, the first lasted over 3 gallons and no tuning was required after the installation of the new plug. This was with the D97T (same lot).
I'm using OS plugs in the GRP and I've had great luck with them as well.
Wasnt intended to derail anything, just wanted some info
madweazl is offline
Old 03-30-2010 | 06:23 PM
  #447
blktransam's Avatar
if anyone wants to buy a 086 send me a pm..have one with 3 tanks on it...not for me sticking with my AE2035...its the chrome version will sell for 40.00 shipped...
Ryan
blktransam is offline
Old 03-30-2010 | 07:41 PM
  #448
vince7870's Avatar
I would suggest the 2041 pipe which I'm currently running but I believe I bought the last 2 from amain that were in the country. I ran the 2041 with p4 and 7mm insert. Was getting over 10 mins in buggy and power was ridiculous. I will be going to the p6 this upcomming weekend.
vince7870 is offline
Old 04-01-2010 | 06:23 PM
  #449
hey joe,
we are having our first outdoor race of the year next week. temps should be in the upper 50's to lower 60's. which plug do you recomend for my full mod?
thanks
nitroal is offline
Old 04-01-2010 | 06:31 PM
  #450
jpalessi's Avatar
Originally Posted by nitroal
hey joe,
thanks
I would go with a P5,, P6 would be too cold for that weather
jpalessi is offline
